Howard Rotavator Chain Noise
Gary
01-16-2004 08:34:40
Thanks for the replys. I have located chain (it is 24B metric)about the same as 120 size. Anyway the price is $13 per foot(corporate account with Diamond) which equates to $60 versus the $478 through the dealer. Applied Bearing indicated the walk in price should be about $30 per foot.The root problem appears to be that the driven sprocket was bored offcenter about .070 and it has sharp teeth on side of the sprocket and new looking on the other side, I'm getting my shop to check to see if it off center or was actually made with half the teeth sharp. I have emailed Howard to see if they can shed some light and want to replace the sprocket. The tensioner is a cast shoe type and it was poorly cast with narrow places (unground) that allowed uneven wear (dips) and also helped make noise, we wear able to grind it smooth which should help.
Hay Dr
01-17-2004 21:26:02
 Re: Howard Rotavator Chain Noise in reply to Gary, 01-16-2004 08:34:40
You are getting hosed on these prices. There are many good sources for Howard parts.
