Using the right implement
Todd Garloff
01-13-2004 13:03:41
I have an acre of land i am inerested in cultivating;half corn and the other half for vegetables. I have a 28hp jd. what type of plow should i be looking to get,ie., a tiller, bottom plow or other. Please explain the different usages for the different plows.
Thank you in advance,
Todd
paul
01-13-2004 15:49:35
 Re: Using the right implement in reply to Todd Garloff, 01-13-2004 13:03:41
Some of this depends on where you are located, what soil type you have, rainfall, what implements are common to your area.
For an acre, a tiller might work best for the veggies, and the corn can come along for the ride, altho tillers often make the ground too fine for real corn/soybean farming. But, your tractor would need a slow forward gear so some of this depends on exactly what tractor you have (3pt?, gearing, live pto?) as well, a new compact JD will do better with a tiller, while an old 2 lung JD will do better wh a plow & disk....
--->Paul
