Ideas on custom furrow maker?
Randy
01-13-2004 13:01:21
Greetings!I would like to get some ideas from some of you implement fabricators on a way to open two furrows in prepared soil for bulb planting. I have a '51 Massey-Harris 44 which does have a 3 point, and I've been told that mounting two discs at about a 45 degree angle off of something called a "tool bar" should be what I need to open a furrow in a prepared bed. I figured that four discs, (2 sets of 2), would work if a guy wanted two furrows spaced the desired distance apart between the rear wheels. Also, do you think that the same arrangement, only with the discs in a reversed direction, could be used to "close" the same furrows after the bulbs were dropped into place? I am very new to this and am trying to start a small-time daffodil propagation business and any suggestions from you more experienced folks would be much appreciated. Thank you very much! - Randy in western Oregon.
paul
01-15-2004 13:55:51
 Re: Ideas on custom furrow maker? in reply to Randy, 01-13-2004 13:01:21
I wonder if you are looking for a transplanter? I live in corn/soybean country, so I couldn't say. But I'm close enough to the christmas tree farms to know that something like a tree planter would do it.
If you would go look at a corn planter, you want _that_ on a magnified scale. You could probably rework one into what you want. The parrallel linkages & depth control would be a big bonus over your good but simple 4 blades on a toolbar (toolbar = a square bar on a 3pt frame to bolt on whatever you want to pull in the ground). It would be better to have the flex and/or spring loading to allow for rocks & uneven ground.
What you want to do is not that terribly difficult, but based on your words, you need lots of pictures or someone else to make it; jut words would be very difficult to describe things so it makes sense to you. :)
--->Paul
ShepFL
01-13-2004 16:35:12
Adding to that perhaps you should consider using existing farm equipment. When I plant spuds I use my front mounted cultivators dropped down and then to close I come back along with disks as you described to close it up.
You may want to look for an old Dearborn 3pth cultvator or a 3pth York rake (rock rake) as it has depth wheels. Either of those could be a baseline that you can adapt for your needs.
ShepFL
01-13-2004 16:33:38
Tim(nj)
01-13-2004 15:02:22
Your idea sounds good to me. You might want some sort of gauge shoes or wheels on the toolbar though so that you can maintain a constant depth.
