Leveling field
CityBoy
01-12-2004 16:26:58
New to all this and don't have a clue. Hogs like to frequent my place and have torn up about two acres. I have a MF35. What implement would be best to bust the mess up and smooth it out? And does anyone know of internet sites that provide detailed explanations on proper implement use?
Thanks
Ol Snuffy
01-14-2004 16:32:27
 Re: Leveling field in reply to CityBoy, 01-12-2004 16:26:58
I got two pieces of rail road iron 16' long, chained one bebind the other and made a cable hitch to hook to the ol JD AW and went to work. When I got done you could have played pool anywhere in the field. P.S. I traded the section forman a fifth of Jack Danials for the rails. Made it a pretty cheap way to leavel my hay fields. Good luck and the .270 isn't a bad idea either LOL
CityBoy - Thanks
01-13-2004 18:38:45
Thanks for all the responses. They provided some good ideas on things I can "rig up" and try without spending money and also pointed me in the direction of disc harrows. I'll be on the lookout for a good deal on a used disc.
Bernie in MA
01-14-2004 16:51:42
 Re: Re: Leveling field in reply to CityBoy - Thanks, 01-13-2004 18:38:45
Make sure the disc is rigid, not flexible
RichG
01-13-2004 16:38:23
I use a 20x10 section of chain link fence with posts 5x5 on each end and pallets with rocks or blocks in the middle. levels a field really nice and you can run what ever way you want.
Bernie in MA
01-13-2004 16:34:37
I use an 8' rigid disc harrow with a wooden railroad tie crossways behind it and a spiketooth harrow behind that. I pull it with a JD 420 crawler. If it's real rough overlap half and if necessary go over it again. Always go in the same direction, back and forth, not round and round.
ShepFL
01-13-2004 07:42:16
third party image
I run a .270 with 140 gr. Nosler Ballistic Tips. After that I follow up with 10' disk with a piece of railroad iron as a drag behind my Oliver 550 Dsl. NOTE: Leaving entrails in the field does not scare off the remaining survivors. Only solution I have found is repeated applications of .270 :)
Stan - Florida
01-13-2004 09:39:39
 Re: Re: Leveling field in reply to ShepFL, 01-13-2004 07:42:16
"Entrails"?? Isn't that what jet planes leave behind them when they're at a high altitude? LOL.
Stan
Roger
01-12-2004 20:20:24
We pull a 26 foot truck frame to level alfalfa fields. Cheap and does a great job of leveling. Anyone that says a good farmer doesn't need to level a field has never pulled something that is 26 foot with no flex. It will amaze you how uneven a field is. It takes 100 hp. Min. to pull it. Try a piece of railroad rail or something heavy like that.
