corn grinders and hammer mills
Gary in MOOzark
01-11-2004 15:57:14
Can anyone enlighten me on corn grinders and Hammer mills. I picked up a stationary corn grinder (about 300lbs) belt driven that I plan on using for grinding feed. They said they used a farmall M to run it at one time. Any idea how big of an electric motor it would take? What is the difference between it and a hammer mill? Thank you
Steven
01-11-2004 18:18:03
 Re: corn grinders and hammer mills in reply to Gary in MOOzarks , 01-11-2004 15:57:14
Is it a Hammer mill, or a Burr mill?
Gary in MOOzarks
01-11-2004 18:46:19
 Re: Re: corn grinders and hammer mills in reply to Steven, 01-11-2004 18:18:03
I am not sure, The only name i can find on it is LETZ made in USA. The chute is about 15 inches wide and has two cast Iron rotors, the top one appears to move about half the speed of the lower rotor. Does that make any sense? Thanks for your time.
Steve
01-12-2004 03:49:24
 Re: Re: Re: corn grinders and hammer mills in reply to Gary in MOOzarks , 01-11-2004 18:46:19
I have a Letz No. 80 10 inch burrs. I run it with my 520 or 620 but burr mills don't take that much power. 10 hp should run it good.
paul
01-11-2004 21:45:43
That is a burr mill. It grinds corn (etc) from course to very fine flour, depending on how you set it up. Don't know the power requirements, ask at some steam engine type sites, they use them a whole lot for displays....
A hammer mill is built very differently, uses a big flywheel to keep the speed up, and hammers the grain through a screen mesh - from 1/4" to 2" size holes is common. Change screens to change the grind. Would need 20 hp plus for most common units I know of.
--->Paul
Sid
01-11-2004 18:06:54
Gary I think they are just different names for the same thing. I have heard both names for the same thing anyway. The smallest hammermills driven by a tractor such as you have mentioned that I have been around would take a very large electric motor and I doubt that it would be feasable to purchase a motor that large. Even though I have know idea about the HP rating required.
Larry806
01-11-2004 20:05:43
 Re: Re: corn grinders and hammer mills in reply to Sid, 01-11-2004 18:06:54
Sounds like what you have is a burr mill There is quite a difference A hammer mill has a rotor with steel knives that spin around It breaks up the grain & drives it through a screen for how fine you want it
Sid
01-11-2004 20:39:22
 Re: Re: Re: corn grinders and hammer mills in reply to Larry806, 01-11-2004 20:05:43
Larry could you tell a little about how a burr mill worked. Was it used for.? Thanks
