vermeer 605a baler
steve
01-10-2004 15:37:17
how about the pros and cons of a 605a baler found one in good shape and the price seems right only gonna bale about 15 acres of hay and 30 cornstalks appreciate any help thanks steve
paul
01-11-2004 21:25:35
 Re: vermeer 605a baler in reply to steve, 01-10-2004 15:37:17
By 'very good price' I hope well under $500....
You'll get the hay made, but even on my 605F with the open throat, cornstalks are iffy to get bales made. Doubt you'll be making any with a A model closed-throat.....
--->Paul
thurlow
01-11-2004 07:31:19
Steve, that flat belt in the bottom that the bale turned on was a MAJOR PIA; personally, I'd look for a later open-throat model; if not that, at least look for a 605C or later; had rolls rather than the big belt..... ..
mike
01-11-2004 04:57:31
we have a 605c and it works fine,hay must be dry, and the cornstalks need to be baled soon after combined,if they get wet ours wont bale them. good luck , mike
Hay Dr
01-11-2004 12:23:26
 Re: Re: vermeer 605a baler in reply to mike , 01-11-2004 04:57:31
It takes a very good operator to bale cornstalks with a 605A baler.
farmerboybill
01-10-2004 19:30:46
Dad has a 605 Super J. Based on our experiance with this much newer machine, I would never buy a differant make. Makes very tight bales and is very reliable. But with a 6X5 bale, you're looking a 2000 lbs. Better have a big skid steer or a tractor and loader.
