Snow Blower RPM
Pete - IN
01-10-2004 14:37:06
Buddy of mine bought a Massey Ferguson model 763 snow blower which was made for 3 point hitch mount. He did a great job converting it to mount on front of his Jeep, and powered it with a Honda motor. We figured it was made for 540 RPM however it doesn't seem to run fast enough. Anyone ever have one of these and can tell me if is supposed to be 1000 RPM? Massey dealer is no help. They say they don't keep manuals for old stuff. PTO shaft did not come with it, so looking at the tractor hookup is not an option. It is 5' wide so was made for probably 50HP or less. Most of the smaller tractors from 20 or 30 years ago were only 540 PTO so this has me baffled
Bob
01-10-2004 15:03:01
 Re: Snow Blower RPM in reply to Pete - IN, 01-10-2004 14:37:06
Are you referring to a 2-stage snowthrower, or a single stage with one large fanwheel?
Referring to 2-stage blowers that I am familiar with, in the 6', 7' or 8' sizes, typically the blower wheel is in the 24" to 30" range, and is driven by a straight-through shaft that passes through the 90 degree gearbox that supplies power to the sideshaft that drives the auger(s), so the fanwheel turns at 540 RPM's along with the PTO shaft.
In similar models set up for 1000 RPM PTO's, there is normally a gear reduction ahead of the fan to reduce to 1000 RPM PTO speed, I suppose to about the 540 RPM's the other models use.
Your 5' snowblower may have a smaller wheel, and need to run at more than 540 RPM's for the fanwheel to have enough peripheral speed to throw the snow a reasonable distance. What is the diameter of your blower wheel?
Could the blower have originally been sold for a compact tractor with a non-standard PTO speed?
Possibly, also, if the blower has sat for a while, and rusted, it will not work as well as when the rust is polished off through use.
Pete - IN
01-10-2004 18:38:25
 Re: Re: Snow Blower RPM in reply to Bob, 01-10-2004 15:03:01
Bob, This is a 2 stage with about an 18" to 24" fan. The PTO shaft goes into a gear box before tranferring power to the fan and augar. Rust is not the problem. You can tell by watching it run that the fan is not turning very fast. Pete - IN
Bob
01-10-2004 20:50:38
 Re: Re: Re: Snow Blower RPM in reply to Pete - IN, 01-10-2004 18:38:25
So, does the gearbox reduce the speed of the blower wheel below PTO speed, or does the power pass straight through, like the 540 blowers I described? If there is a reduction, I would be almost certain the machine is designed for a PTO speed greater than 540 RPM.
