NH 310 and 273
Brandon
01-07-2004 17:12:56
I'm gonna be workin on a 310 soon and i'm wondering if it is possible to put 273 gears in the gear box to slow the plunger speed down or if it would be too much of a project. Thanks for your help.
RickB
01-08-2004 15:47:03
 Re: NH 310 and 273 in reply to Brandon, 01-07-2004 17:12:56
Why not just slow down the PTO speed and maybe grab another gear? Nothing on the 310 runs off the input (pinion) shaft except if it has a thrower. You can max out the belt thrower variable speed adjustment and/or alter the spacers on the split sheaves on the 90 degree belt to maintain thrower speed. If it has a 75 pan kicker it should do fine at less than 540 input speed. I can think of better things to do than swap out a perfectly good baler gearbox.
Frank
01-09-2004 06:59:28
 Re: Re: NH 310 and 273 in reply to RickB, 01-08-2004 15:47:03
Operating at less than 540 pto rpm is what I've done with the 310 I have. Baler & belt thrower both work fine and even my Kubota 5700 has plenty of power to run the system at 80-90% of "normal" pto operation.
Steve from New Holland
01-08-2004 04:27:49
Yes, that will work. But why not switch complete gearboxes? That would be easier. Steve
Brandon
01-08-2004 04:30:27
 Re: Re: NH 310 and 273 in reply to Steve from New Holland, 01-08-2004 04:27:49
Thanks Steve, that sounds like a better idea!!
