Long distance baler transport
John
01-06-2004 19:24:14
Hello all, I'm thinking about buying an older baler to take in a few acres of hay. I live in Connecticut and was thinking about looking in Pennsylvania as they are much more plentiful and cheaper too. How do you move a baler in a situation like this? What size trailer? Thanks
Bernie
01-08-2004 17:25:40
 Re: Long distance baler transport in reply to John, 01-06-2004 19:24:14
When they brought my JD14T baler on a truck from VT, about 100 miles, they had a little wheel assembly that bolted/clamped to the baler frame underneath. The 14T small wheel is on the outside of the frame, too wide for a truck bed. The 24T wheel is moved under the frame, but I never tried to load it on a truck. HTH
markct
01-07-2004 08:47:25
where in connecticut are ya, theres a slight possibility i may be selling my baler before this haying season, NH 268 with kicker, works pretty good but i might be moving away if things go well
Jim in michigan
01-07-2004 08:18:25
I agree with Don,,we haul all over, living in the U.P or wisconsin you have to pull a long ways to get anywhere...Jim
stumpy me
01-07-2004 07:39:43
I have used a tagalong trailer to haul a baler.
Load the baler on the flywheel side down using
blockingto keep the flywheel off the floor and remove the tire on that side.Thats how i use to haul them when i hauled for John Deere to the dealers. stumpy
Don-Wi
01-06-2004 20:17:48
Check out all tires, maybe put on some old but good car tires, check the hubs/bearings, grease & go. If the wheel assemblies are in good shape, it will stand up to a long road trip. I have a magnetic set of trailer lights that I use on hay wagons, the haybine, baler, etc. They work great, just be sure to stick them on top, not on the side, or you'll lose them on the 1st bump. I pull just about anything with 2 wheels on my farm at 55+, some I'll trust to pull 65+
Donovan from Wisconsin
Frank
01-07-2004 06:33:13
 Re: Re: Long distance baler transport in reply to Don-Wi, 01-06-2004 20:17:48
It should be noted that (New Holland's) "recommended transport speed" for balers is 20 mph! Even a compact pickup can easily get them up to 50+ but the problem is stopping; there are no brakes on that towed implement. Think about what will happen if you have to react to some situation by hitting the brakes while towing a baler at 50 mph.
If you buy now, it seems like you would have enough time to find a hauler going your way before haying season.
Duane(Pa)
01-06-2004 20:45:50
Um... Stay where you are Donovan. I would look for a rollback type truck. Connecticut is quite a bit up the road from Pennsyltucky.
