JD 14T Baler Questions
Bill
01-06-2004 18:11:42
I have a JD 14T baler that is a 1962 model year make. I also have a 14T that is a 1958 model year make. These two balers, while similar are yet different - at least with respect to the knotter assy. My question is - can I completely replace one knotter assembly (frame and all) from one baler to the other. Also, other than the knotters, how similar are these balers with it comes to exchanging parts?
Thanks in advance,
Bill
Tom Smith
01-08-2004 15:54:58
 Re: JD 14T Baler Questions in reply to Bill, 01-06-2004 18:11:42
Mr.Bill,
the later series knotter assy. will work,one surprise will be the trip dog assy. it's different from the early series( I had to drill a hole in the bale chute to mount the bale lenght assy. If you change the whole knotter frame shouldn't be too bad an experience. The later frame is almost a 1/4" wider than the earlier models. hope this helps. Tom N.E.Ga.
Colorado Curt
01-07-2004 07:49:02
I used a 59 14T for a while and had to replace a knife arm. JD had a universal replacement from a modern 348 that came with a bushing to work on the 14T. There was a slight interference with the angle iron on the chamber, but I took care of that with a grinder. These knotters have not changed a whole lot over the years. It should work to swap the whole knotter. Take your time and make sure the timing and clearance is correct for the needle bringing the twine up. Good luck.
