JD 327 or NH 273??
Buck
01-05-2004 13:55:23
What's your opinion of these balers? How do they compare as far as capacity. I'm lookin for one without a thrower so that isn't an issue. Are these balers pretty reliable? Do they make nice bales? Any other comments would be great.
Rick
01-07-2004 00:36:06
 Re: JD 327 or NH 273?? in reply to Buck, 01-05-2004 13:55:23
I handled bales behind 273 New Holland when kid and we always called those the banana balers. I ran a Deere 327 for about 10 seasons and loved it. Any baler that has the packer fork will simply give you more uniform bales with less hassle. Between those two models it is 327 period. This baler is still going sold last season. He now has two of them and loves them. I just needed more capacity as I bale behind combines with 25 and 30 ft heads. Rick
Indydirtfarmer
01-06-2004 12:49:52
I guess that I can give as good an opinion as anyone. I have BOTH of those balers. I had the Deere for about 5 years, and bought the New Holland this past year, as a "back-up" baler. We do a lot of straw. I haven't baled much with the New Holland yet, but it did a very good job on the little hay I did bale. The Deere is a VERY good baler. As good as any baler ever made, in my opinion. You will have a bit more capacity with the Deere. You won't go wrong with either one, provided they are in good shape. JMHO. John
Doug in IL.
01-06-2004 08:56:24
Deere balers make good, solid bales. Capacity wise, I think these two would be similar. I do like the auger feed system on the Deere's better though. I had a NH 276 once and had to repair that spring loaded finger feed system after a wreck. Lots of dollars!
RichZ
01-06-2004 06:40:26
I can't tell you about the JD, but I've got a NH 273, and I've been very happy with it.
Duane(Pa)
01-05-2004 18:53:12
Pretty sure the 327 would be newer. They are both good balers. Parts would be no problem for either one.
Mike
01-05-2004 16:43:49
I bought a NH 273 about 5 years ago. I bought it at an auction--brought it home cleaned it up. I found that the knotters were rusted and when I tried to bale caused me some problems. I couldn't clean them good enough so I replaced them. Haven't had any problems with the baler since--does a great job baling!
steve
01-05-2004 15:47:44
i own a nh 273 w/kicker ,not to much trouble with it i have had it for 3 yr and alot of hay threw it .... i think nh is the best, always brings high dollars at the sales ..
