lookn at buyn a 479 nh what do you think
jackel galvest
01-03-2004 19:19:19
found me a 479 moco.and they dealer is askn 1000$for her he says she ugly but she should cut hay.said the rolls are not too bad sent me some picks its rusty but looks ok.Does this model use a cylinder?looks like there is a place for one but perhaps its missing.what do i need to look at when i go look at it?roll,bearings cutter bar,gear box?anything specific for this model?will be my first mower.
jackel
01-05-2004 08:25:27
 Re: lookn at buyn a 479 nh what do you think in reply to jackel galveston,in, 01-03-2004 19:19:19
so i take it these machines run two gearboxs?am i correct?one for the sickle and the other for the reel and rolls?i will check out the tongue.dealer said there is some spots were the rubber is missing in the bottom of the cheverons close to the metal drumthat it is adhered to.you guys are great!i have learned so much.anymore ideas?well talk later everyone have a good day.
FrenzFarms
01-04-2004 07:22:47
I think you're getting a deal at $1000 (especially from a dealer). I literally just bought a 479 myself after searching every state within 300 miles. I paid $1500 for mine with some smooth talking, from a private individual and that came with an extra knife and a manual. I think the suggestion to have it hooked up to a tractor is the best bet. That's what I did to confirm everything was doing what it was supposed to and nothing it wasn't supposed to do. There are a couple of things to check especially; make sure the rubber on the rollers hasnt started to delaminate in chunks, and make sure the reel drive isnt grinding, and of course as previously noted check the wobble box, and just visibly (but carefully) watch everything go round and round and back and forth. If all looks reasonably decent, I'd snag it. New Holland makes good hay equipment. Period.
Rick
01-04-2004 01:34:31
I have a 469 and 489 for sale if that would help. Have some other machines also. Rick
Sid
01-03-2004 20:38:16
Yes it needs a cylinder to raise. You sem to have pretty well listed what you need to look for. I think the main thing would be the wobble or gear box if it seems to have slop in it I would walk away. I have never bought one but hear they are high dollar. For a thousand dollars I think the cylinde should be included and since he seems to imply it is field ready at that price he should be willing to make some kind of agreement as to what you can expect in the way of a warranty of some kind I know it wouldn't be much but he should be willing to stand benind his word. A lot of almost worn out machines can cut hay. Just my thoughts which may or may not be good advice since I ain't charging nothing for it there is no warranty implied or otherwise.
Gary in TX
01-03-2004 20:36:28
I have a 469 which is its just older brother and have had a 488 which came after the 479. They are good cutting machines. Yes they do use a cylinder 3x8 is what mine has on it. You will want to get some depth stops to put on the cylinder rod to set the depth you will want to stay with. Check for play n the gearbox, wobble box and the roller bearings. If possible have the dealer hook it up to a tractor and listen too it run and watch everything on it. The 479 will have the big sickle head with a bolt holding it in adn thats a good thing, I modified a 488 sickle head to use on my 469 to be able to do this, worked good. Look the tongue over good to make sure its not cracked, they put a thin piece of square tubing on them in my opinion, I have had 3 haybines and have only broke one. It will be pretty much self explanitory to what to look for if you can see it under power at the dealer. Hope this helps.
Gary
RickB
01-04-2004 02:51:59
 Re: Re: lookn at buyn a 479 nh what do you think in reply to Gary in TX, 01-03-2004 20:36:28
These machines should not use a depth stop on a standard 8" stroke cylinder. Set the cuting height with the skid shoes, and flotation with the spring tension. Lower the cylinder fully. Running the machine on the cylinder will twist the mainframe tube between the header mounts over time.
Gary in TX
01-04-2004 13:43:10
 Re: Re: Re: lookn at buyn a 479 nh what do you th in reply to RickB, 01-04-2004 02:51:59
Well, I've got countless hours mowing with them this way and never had a minutes problem out of them! Got a lot of acres mowed with them too. I'm not saying that there couldn't be a problem and I know the skid shoes are there for the purpose of skidding on the ground. Main reason why people tear their machines up is they are running them like maniacs and not knowing what they are doing.
RickB
01-05-2004 03:30:14
 Re: Re: Re: Re: lookn at buyn a 479 nh what do yo in reply to Gary in TX, 01-04-2004 13:43:10
I figured you would come back with a response like that, and I'm not gonna argue if that works for you. I wanted to get a potential new operator to run his the way NH intended, that's all.
jackel
01-05-2004 08:13:31
 Re: Re: Re: Re: Re: lookn at buyn a 479 nh what d in reply to RickB, 01-05-2004 03:30:14
hi guys i thank you for the info thats what i was after your experiances and ideas are what i dont have.i dont want nobody gettn all excited and i think everyone has ideas and the reasons why they do things that work for them.i hope if i get it i can get the manual on it and learn all i can about it.
