Oliver 3240 plow
J.Cahill
11-05-1998 12:57:07
Any body know much about an Oliver 3240 plow. It is a 14" 2 bottom. I want to use it on a Ford Jubilee with a sherman transmission in farily light soil. Is this too much for this tractor? What might this be worth considering it seems to all be there and only surface rust.
Al
11-06-1998 20:50:41
 Re: Oliver 3240 plow in reply to J.Cahill, 11-05-1998 12:57:07
I have an old Oliver 14" 2 bottom plow (not sure about the model number). I have used it with both my Fords (8N and 3000). Of course, the 3000 pulls it with no trouble, but the 8N does okay if it's set up properly and I don't bury the plow too deep. I also have some clay in my soil, so it might work even better for you,
tim(nj)
11-06-1998 07:21:11
: Any body know much about an Oliver 3240 plow. It is a 14" 2 bottom. I want to use it on a Ford Jubilee with a sherman transmission in farily light soil. Is this too much for this tractor? What might this be worth considering it seems to all be there and only surface rust.
I can't tell you about the plow (except that Olivers have good reputations). However, my grandfather pulle a 2-14" JD plow with his NAA (no Sherman) in heavy clay soil without trouble, so you should be OK as far as that goes.
