Implement Painting Recommendations
Bill
12-28-2003 19:36:02
I am getting ready to begin cleaning and painting my JD 14T baler and have a few questions about painting one of these (and any other piece of equipment).
What kind of paint do you use? The real JD stuff is right expensive is there an alternative you would recommend? Do you brush paint, spray with cans or spray with a gun? I had thought of cleaning the surfaces to the extent I can (and can reach) and using rust-o-leum rusty metal primer followed by implememt green (yellow on the wheels!) in a spray can.
Also, the decals on this baler are in good shape, just faded. I'd like to mask them so as not to cover them with the new paint. How would you recommend I do this? I'm afraid that if I simply use a masking tape, I will pull off the lettering or damage it when removing the tape.
Any advice would be most appreciated.
Thanks in advance,
Bill
John in IN
12-29-2003 17:02:27
 Re: Implement Painting Recommendations in reply to Bill, 12-28-2003 19:36:02
I have used John Deere dealers paint and it worked well. I have painted my dads J.D. A and my 851 J.D. hay rake with J.D. Ag green ($32.00 a gallon). Use there primer and thinner. Don't mix brands you are taking a chance. I have used Valspar ($20.00 a gallon) a gallon. from TSC on my N.H. baler with some Valspar hardner ($8.00)that turned out real good. Valspar is a supplier to some major OEM companies. The specs may be different than the Valspar sold at TSC. I think its good paint. I used carb cleaner on my knotters sparingly to get the off where I didn't want it. The best advice is clean, clean, clean. It can't be to clean. Good Luck. John
Charlie
12-29-2003 14:23:41
A lot of the cheap paints will fade very quickly when exposed to sun. I'd go with the better paint and not have the job fade away within a few years.
kyhayman
12-29-2003 05:00:47
Go with the JD paint and JD thinner. It's worth the difference in color match and durability. Generic paint runs about $20.00 per gallon. I just got a gallon of JD green from the dealer and it was $42.00. $22 extra over all the work and effort of painting a piece of equipment is a small investment.
Larry NE IL
12-28-2003 20:33:23
Just cover the decals with vasoline petroleum jelly
Tim(nj)
12-28-2003 20:22:57
There used to be a liquid film available that you could brush on an area you wanted masked. It went on wet, then made a latex-like coating that was enough to keep the paint off, but it didn't have much stick to it, so you could simply grab it and peel it off without damaging anything. Magic Masker was its name, I think. I haven't seen it in years, though. Spray painting with a gun will be quickest, and will give you the nicest finish as long as you don't let the paint go on too thick. For painting a baler, I recommend removing the knotter assembly. Did that on a 336 once. Saves a lot of grief by not getting paint in the knotter to gum up the works. Also allows you to clean out the accumulation of dirt around the knotter area so the paint will stick to the steel.
Kelly C
12-28-2003 20:19:13
third party image
Cant help you on the decales, but I have painted a baler. I used the cheap stuff fron Fleet Farm.
I purchased 1 gal of NH red and about 6 or 7 spray cans of NH yellow. Also a gallon of red oxide primer. Primmer is a must with this paint as it does not stick worth a darn to old paint or bare metal.
For spraying I use the cheap sprayers you can get at Harbor Freight for like $12. I use them 2 or 3 times then throw them out. I hate cleaning spray guns.
Will- Mn.
12-29-2003 05:49:05
 Re: Re: Implement Painting Recommendations in reply to Kelly C, 12-28-2003 20:19:13
Hey Kelly,
Nice looki'n New Holland ya got there! i e-mailed ya a few weeks ago about your throw out bearing n clutch for a model H Intl. but got no response,is that when your e-mail was messed up? i'll be back at the farm in Foreston Mn. on Jan 5th, BTW i got up 2 crops of hay last summer with my John Deer 336 n thrower,hope your haying went fine also
Will
Doc
12-29-2003 08:56:47
 Re: Re: Re: Implement Painting Recommendations in reply to Will- Mn., 12-29-2003 05:49:05
I have a JD manure spreader Model R and
serial #1 that I want to restore this summer. I would like some information
on this equip. like how old is it,did
it have decals on it and was it painted
all green with yellow wheels.The wheels are
metal dished with rubber tires.It is just
weathered from sitting outside. Any information
would be appreicated.
Leroy
01-01-2004 18:58:17
 Re: Re: Re: Re: Implement Painting Recommendations in reply to Doc, 12-29-2003 08:56:47
Sounds like you have the optional hubs to use old truck dual wheels with 20" tires, that would be series - not serial no., series 1 would have the 2 lever setup instead of later style single lever, yours sounds like mine
big man
12-30-2003 23:11:57
i also have a model r spreader it was made in the early 50's and yes it was all green with yellow wheels be sure you put plenty of grease in the wheels because those bearings and hubs aint cheap my local dealer told me where to find a parts catalog and it is a must have as it has all the current part #s and they are all still available from deere.
