6.00-16 tires
Dave@NY
12-28-2003 18:48:35
We've got a couple of old carts and trailers that have 6.00-16 tires on them that need replaced. All these tires are light truck type that Dad got someplace years ago. It's not really worth it to buy new implement tires to put on these old carts. So where does a guy find an inexpensive tire that would work? Thought of using the space-saver spare type tire, but they are quite small and narrow.Any ideas?
scotc
12-31-2003 15:31:34
 Re: 6.00-16 tires in reply to Dave@NY, 12-28-2003 18:48:35
call around some tire shops and see if they have used or recap tires similar in size to a 6.00-16. Even if its a little narrower or wider it'll work.
M guy
12-29-2003 17:43:13
Dave, the biggest size truck temporary spare in a 16 inch works pretty good. Not EXTREMELY durable though. Mguy.
Dan
12-28-2003 19:51:59
Have had the same trouble finding good used tires. Needed some for an eversman leveler a couple years ago. Got some from a local tire dealer who got them from a guy who restores old cars, puts new tires on once in a while. They were 650 X16 but worked fine. Also got some from a tractor show a few years back. My local tire dealers usually don't have any decent 600 X16, guys wear them out before getting new.
michael Soldan
12-28-2003 19:23:49
Dave , lots of newer cars are using 16 inch tires, if the carts aren't being loaded heavy you can find used or throw away 16"tires that would likely do. I found a couple of 16" light truck tires for one of my hay wagons..worked well, have a wider profile though, a p205 60 16 or p215 65 16 would work well on the older narrower rims. We often have 16" throw aways at the shop , any tire place would likely be glad to give you a set of 16's just to get rid of them..... ...Mike in Exeter Ontario
Dave@NY
12-29-2003 17:59:19
 Re: Re: 6.00-16 tires in reply to michael Soldan, 12-28-2003 19:23:49
Thanks for the ideas! A fellow told me today that he has used 16" motorcycle tires in place of the old type.I wouldn't think a bike tire would have much of a load rating.
rubber wrench
01-01-2004 09:33:13
 Re: Re: Re: 6.00-16 tires in reply to Dave@NY, 12-29-2003 17:59:19
i have used motercycle tires for 10 years with implement tubes no problems
tooly
12-29-2003 21:38:58
Had the same problem with an old farm wagon we have on the farm . I used a set of used 3/4 ton truck tires, which were marked 7.50x16.
I even used the old 6x16 tubes with no problem,yet.I think these were in use in the eighties on these trucks, not sure what they use now. My 1/2 ton GMC (2003) uses 16 inch so I'm hoping they will work when i wear them out, as I have a few of those oldtimers around needing tires.
Dave@NY
12-30-2003 16:48:57
 Re: Re: Re: Re: 6.00-16 tires in reply to tooly, 12-29-2003 21:38:58
One of the carts is made from the back half of a "51 chevy pickup.So having 6 lug wheels I think that Datsun trucks had same bolt pattern on a 14" rim.Have to do some research on that.
Leroy
01-01-2004 19:02:06
 Re: Re: Re: Re: Re: 6.00-16 tires in reply to Dave@NY, 12-30-2003 16:48:57
the wheels 15" from Chevy - GMC trucks fit and they are also the same wheels that some trailer axles take
big man
12-30-2003 23:15:41
datsun and toyota
