494 A planter
Hank
12-25-2003 13:41:17
What type of tire tread is used on a 494 A planter??
Fern(Mi)
12-25-2003 15:19:16
 Re: 494 A planter in reply to Hank, 12-25-2003 13:41:17
we had used whatever held it up making sure both tires were of the same make like size.
Sean W
12-26-2003 21:50:36
 Re: Re: 494 A planter in reply to Fern(Mi), 12-25-2003 15:19:16
You can probably use a implement tire with no problems of slipping. My 494A has plain implement tire and I run in clay ground, and I don't have any troubles. Now if you live where your ground is always soft, you might want to have cleat tires. I believe the commom size of the tires are 6.00x16. Hope this helps!
Leroy
12-27-2003 15:58:27
 Re: Re: Re: 494 A planter in reply to Sean W, 12-26-2003 21:50:36
The 494 & 494A both used 6:70 X 15", you could buy a tractor tread tire with the planter new but most just used old car tires
