adding cyl to bucket
Chuck
12-24-2003 17:33:29
third party image
Guys,
Was wondering if there was an easy way to make the bucket work with hyd in stead of trip. Such as adding a cyl to bucket. How would I hook it up.
CHUCK
Irv
12-26-2003 11:14:28
 Re: adding cyl to bucket in reply to Chuck, 12-24-2003 17:33:29
I added a cylinder to the bucket on my loader. It looks identical to yours, right down to the release mechanism for the bucket. It is a 40 in bucket. I added a plow cylinder to the middle - off a snowplow - just plumbed it into the valve. I got a valve off an old forklift. It is a 3 way, but I only use to 2 sections. I cut a piece of cardboard out to see where to weld the clevis on. I had steel lines made up for the cylinder back to the brace. I have seen a buch of ripped hoses. Good luck. TSC sells a 2 way valve for 150? Irv.
JMS/MN
12-25-2003 06:59:10
That looks like a Paulson loader on the tractor. I have one on a WD that I converted from trip to a double cylinder. If you contact me by email I can send you a picture of it. Not sure about how to post the pix here. I think the cylinders were 2 or 2 1/2 inch diameter, either 20 or 22 inch stroke. You definitely need two-way hydraulics to run a cylinder bucket, and a double cylinder is simpler to set up and a better conversion.
Dan
12-24-2003 19:06:00
I put a cylinder dump on a #35 JD loader a few years back, had a trip bucket prior to that. I definitely takes some comtemplation. You need somewhere on the frame solid enough to act as a base for the cylinder mount. Your angle to the bucket has to be so that it is pushed foreward when the cylinder extended. You need a long enough cylinder to completely dump bucket but not one so long that it does not allow the cylinder to completely retract. If you look in a source like Northern tool it tells stroke, length etc of the cylinder. Also consider if you want 2 cylinders or just one in the middle. I put one in the center on my JD but will someday change to 2, one on each side. You need a cylinder with sufficient ram diameter that it does not bend when you put pressure on it. You usually need 2 way hydraulics to operate the bucket cylinder effectively. One more thing to consider, the cylinder or cylinders add extra weight to the loader, so harder to steer. I am glad I changed mine over but just offering some considertions.
Jim in michigan
12-24-2003 18:14:22
we have done several here, you have to make sure you put your cyl mounts on at the proper place or they wont work right,,I tip the bucket then figure out the cyl size I need. then I locate the best spot on teh bucket and the loader for the cyl... if I can help just holler,,,Jim
