494 A Planter
Carl
12-23-2003 13:09:35
What years was the 494 A planters made????
Fern(Mi)
12-24-2003 04:24:45
 Re: 494 A Planter in reply to Carl, 12-23-2003 13:09:35
Used a 494A for years. Good planter. eem to remember we needed another set of plates every time we bought each seasnon's supply of seed. The duy buying it to plant a few acres of corn for his northern Mi. hunting canp took it away with a pickup truck. The truck to pull it. The truck to haul the plates.
Leroy
12-23-2003 18:08:33
the 494 was started in 1957 for several years, then went to 494A. Mine I bought as a 69 model, if it is or not I cannot verify
JMS/MN
12-24-2003 08:20:09
 Re: Re: 494 A Planter in reply to Leroy, 12-23-2003 18:08:33
Big improvement on the A version was the square bar in front of the frame- for the fertilizer openers. 494 had a pipe there, and the openers would rotate on the pipe when hitting rocks. Hard to hold in position. Good planter in its time.
Leroy
12-24-2003 13:51:50
 Re: Re: Re: 494 A Planter in reply to JMS/MN, 12-24-2003 08:20:09
If the openers would rotate on the pipe they wern't all there
JMS/MN
12-25-2003 07:14:11
 Re: Re: Re: Re: 494 A Planter in reply to Leroy, 12-24-2003 13:51:50
The openers did have some braces made out of rod, but they didn't stay too straight when they met rocks just under the surface.
Tim
12-23-2003 13:46:58
57'-67' very good planters.
Sean W
12-26-2003 21:57:08
 Re: Re: 494 A Planter in reply to Tim, 12-23-2003 13:46:58
I'll second that! I use my 494A for alot of sweet corn. I always seem t have a good stand, but needless to say the summer's heat always gets it. I may plant too much and give alot of it too friends and family, yes the neighbors too. Good times during the summer.
