STILL NEED HELP, HELP, HELP, HELP for Plow plans
Benj. J. Joe Br
12-21-2003 20:56:27
Hello Everyone, Thanks for all the information about building a three point single bottom plow from my other posts. I want to home build it and use it behind a Kubota 19 hp B8200 HST tractor.I certainly can see there are some difficulties in constructing one. However nothing that seems insurmountable. The problem is I really do not want to buy a two or three bottom and cut it down, nor do I want to buy a new Howse or other brand plow. Another factor is I've got the time, steel and the actual plow portion off a wrecked older plow that I'm sure will work. I'm very reluctant to try to build one without plans. I just have not be able to locate plans or a plow to take measurements and make my own. At this point, it appears that I'm still dead in the water. I'm open to all sugesstions, links to possible help or any other ideas. Thanks, Joe
ed
12-22-2003 19:55:58
 Re: STILL NEED HELP, HELP, HELP, HELP for Plow pl in reply to Benj. J. Joe Browning, 12-21-2003 20:56:27
don't you have any skills, design your own for pete's sake. Build it as you go. Better yet, go down to TSC and buy on for $150, brand new, I guarantee you will never wear it out on your garden.
Brian
12-22-2003 19:14:57
Guy named John Deere beat you to it by a few years. Good luck.
SteveB(wi)
12-22-2003 13:01:35
You can buy a new one not a great one pretty cheap W/O the headaches
paul
12-22-2003 09:11:07
A picture vs 1000 words.....
Go to machinery dealers, & take some pics & measurements.
Never saw any plans to build your own, as there are so many plows rusting away out there - buy a single bottom for $75 & rebuild it. Takes more iron & rod than $75 for most people, so you are a rare bird to have the parts but not a plow frame.
--->Paul
Norm
12-22-2003 07:36:57
Isn't this kind of like re-inventing the wheel?
Hugh MacKay
12-22-2003 01:59:02
Joe: Have read your post an agree your project is not insurmountable. However before anyone can help you they must know exactly what you have. In fact the only way I would tackle it is by having a couple of photo shots of what you have. I have done this before and can assure you photo is only way to go.
