Henrichs
12-19-2003 13:44:51
Re: Hay Rack Questions in reply to Matthew (Mich), 12-19-2003 12:55:59
On the bed of the flat rack, you want to leave at least a 3/4" to 1" space between the boards, using 1" foot boards. Make a minimum of a 16 ft. rack but an 18 ft would be a lot better to give you a little extra room, otherwise four rows is all your going to get on a 16 ft. rack. What do you think the bales will weigh? A small bale will be a minimum of 50 lbs. while I've baled some that weigh 80 lbs. How high do you want to stack the bales, 4, 5, 6, 7, 8? I generally do 6 high, I've seem good rack riders go to 9 but you better have level ground, no pocket-gopher holes and an experienced operator on the tractor. Running gear size is going to be determined by a number of factors. If you want to put a minimum of 100 bales on the rack that weigh 50 lbs. each, that's 5,000 lbs. plus the running gear (800 lbs. approximately) and the rack (another 500 lbs. minimum) so now we are up to about 6,500 lbs. and a 4-ton gear will work. But, 100, 80 lb. bales will give you 8,000 lbs. with the running gear and rack your going to be pushing 10,000 lbs. Don't waste your money on a 4-ton running gear, the wheel spindles and bearings are to small, and the tounge will not be heavy enough for turning. A cheap 8-ton running gear will cost you a little less than $1,500 and a good wooden rack if you build it will be about a grand. Use 4x8 stringers.
