I need Help Identifying a 3 bottom plow
Daniel McKinney
12-19-2003 10:04:01
I need help in finding more info on a 3 bottom plow, the best I can describe it is.. it has steel wheels,3 bottom plows,and has a steel seat on it. should there be any markings on it that should give me more info on plow to be found on it stamped somewhere..right now the plow is dirty and weathered and covered in thistles
Pete - IN
12-20-2003 19:16:41
 Re: I need Help Identifying a 3 bottom plow in reply to Daniel McKinney, 12-19-2003 10:04:01
As one of the other guys mentioned, if it has a seat, it was designed to be horse drawn. I have never seen a horse drawn 3 bottom plow. I live near an Amish area. Most use 1 bottom and only occasionly will you see a 2 bottom plow being used. It would take a heck of a bunch of horses to pull a 3 bottom.
Hugh MacKay
12-19-2003 17:11:43
Daniel: You've got me curious, 3 bottom plow with a seat. Had to be designed for horses or mules. Can you get a picture? Or can you describe more detail? Any sign of paint anywhere? Even just a bit. I have quite good books on IH and Oliver plows. Keep going, this one is a gem.
Nebraska Cowman
12-19-2003 17:10:18
plows were poorly marked and unless you can find a trademark on the castings or recognise the numbers you about out of luck. Get Alan King's book "Horse Drawn Plows" maybe you can find it pictured in there.
