int b-414
scott hicks
12-14-2003 18:48:41
I have int b-414 gas tractor with a zenith vnn carb on it which came stock on this model. It has been a lot of trouble since I got it 4yrs ago. Has anyone been able to find a different carb or model of carb that will work on this engine? No carb shops around here can even get parts for it or wants to take on the job of fixing this oddball.
Stan - Florida
12-21-2003 07:51:22
 Re: int b-414 in reply to scott hicks, 12-14-2003 18:48:41
Someone else mentioned that Mahindra of India made these tractors. It might be a wild idea, but maybe if you checked www.mahindra.com you might be able to contact someone there or find a U.S. dealer that could help.
The first time I saw a Mahindra I thought I was looking at a B414. Not being a real knowledgeable IH guy, I could have been wrong, however.
Good luck,
Stan
Chris Brown
12-16-2003 15:42:08
I re drilled the intake to accept a one barrel rochester off a nova 250 I think,I used 1/4 inch studs .. It took a little tinkering to get the linkage to work.The only real problem I had was the air intake pipe didn't fit anymore,but it ran great. I duct taped the air intake and sold it.
jdemaris
12-14-2003 19:46:17
Perhaps a stupid question, but did you try your IH/Case dealer? I've been getting pretty much any parts I need for my Indian-made International.
I have a 1960 B-275; I think your's is year or two newer, but almost the same tractor. B stands for British although the tractors were made by Mahindra in India.
randy in pa.
12-15-2003 15:02:09
 Re: Re: int b-414 in reply to jdemaris, 12-14-2003 19:46:17
I had a 3414 which is the same as yours but is the construction model. I always had carb problems. By my own looking I found a needle and seat out of a mukuni [spelling???] snowmobile carb that fit. my case construction dealer gave me the name of a person that I think was in Ill. that made a bolt on kit w/ a new american made carb. an adaptor to bolt on to the manifold and an adaptor to hook up to the stock air cleaner. I called him but the price was $575.00 I used the tractor for another year and traded it. If your interested I may be able to find the #.
