white 5400 air planter
jim ball
12-14-2003 16:02:11
i have a chance to purchase a white 5400 air
planter in excellent shape. are they good &
how do they work ? the pto runs a pump. what is this for ?
txs -- jim
Wayne in Pa
12-15-2003 14:30:47
 Re: white 5400 air planter in reply to jim ball, 12-14-2003 16:02:11
I have a 5400 white planter. The one I have has small electric motors with a blower (like a heater fan in a car) on each row unit. The fan pressurizes a chamber that holds the seed. The preasure holds the seed to a disk that turns on a verticial plain as the seeds pass a cutoff valve the pressure is cut off and the seed falls to the seed futtow. I hopu you understand my explanation. I dont know about a PTO driven pump, some planters had a PTO driven alternator for electric for the motors if your tractor did not have a big enough alternator.
The disign of this planter is you do not need a lot of seed plates, most seed sizes will fit on 1 or 2 plates.
Larry from MD
12-16-2003 13:36:08
 Re: Re: white 5400 air planter in reply to Wayne in Pa, 12-15-2003 14:30:47
The hydrolic moter runs a fan to supply the air preasure.Hydrolic planters are the newer ones and work better with less problems.The pumps are very expencive to replace so see if it works fist.
