New Idea Hay Loader
Mark
12-14-2003 07:30:56
I have a New Idea Hay loader as a display in my front yard which is hooked behind a John Deere 802 all Steel Running Gear with the double ended flat rack you would of found when using a hay loader. I'm looking to make a plaque for the display with years and models of implements. However, I need to know approx. what year or model the Hay Loader is. The only piece of info that is tagged to this machine is Lot 62. I had a New Idea steel wheel side rake years back that had the same tagging. Is there anyone out there with info on how to decipher the machines on such sparse info? Also, I'm looking for someone to make a plaque and I wanted it to be set up like the ones that you see on tractors and implements at shows. I think they are using plastic with etching in it in the colors of the tractor or implement. Does anyone have the # for someone doing these. However first I do need more info on the hayloader. I'll be having bushes and other things on this display and when it's done next summer I'll try to post pictures. I've got the wagon set up with horse yokes and old hay pitch fork and also hay forks that would of taken load into barn. If anyone can help me on this project with info I would greatly appreciate it. Thanks, Mark
Leroy
12-15-2003 19:13:43
 Re: New Idea Hay Loader in reply to Mark, 12-14-2003 07:30:56
I don't have the lot information for the hay loader but I do have for the hay rakes and some for manure spreaders
Tim(nj)
12-14-2003 21:31:00
Get in touch with Norman Macknair. He specializes in the old stuff like that hay loader.
JMS/MN
12-14-2003 17:00:17
New Idea is now a part of AGCO- might be a source of info. Older dealers might be a better source.
