Ford Jubilee and Hay Bailer
Mike
12-13-2003 19:27:39
Is the Ford Jubliee strong enough to operate a bailer? If yes what type, where would I find one?
Thanks
ErnieD
12-14-2003 15:54:34
 Re: Ford Jubilee and Hay Bailer in reply to Mike , 12-13-2003 19:27:39
It will work unless you have hills and like big loads. Look for a JD 14 ir 24 "T" baler. We would drop on ground then stack on the wagon for hills.
JB
12-14-2003 07:30:04
I RUN 14T WITH A NAA WORKS FINE, DRAW BACK IS NOT HAVING LIVE PTO.
Bob Semrau
12-13-2003 20:00:39
I used to run a NH 66 PTO baler with my Jubilee, and it worked fine. I could even pull a wagon while baling on flat ground. One point though - my Jubilee has the live PTO option - that helped. I think that you will have more than enough power.
old
12-13-2003 19:42:58
Its just enough to run a square baler but you will be pushing its limit unless you find one with an engine on the baler then it willbe fine. Some old JD 14Ts etc where good but they are getting hard to find in good shape
