How to measure a plow
Curious
12-12-2003 04:30:12
I am looking at an old plow to buy and restore. Can someone tell me how to measure it to see if it is a 12", 14" or 16"? Thanks!
Lary
12-12-2003 14:46:03
 Re: How to measure a plow in reply to Curious, 12-12-2003 04:30:12
Curious;Measuring from beam to beam is ok on some plows, but the JD 44's that I sell all have a slight jog in the legs, you can switch legs and get a dif.spacing if needed. I would measure perpendicular to the direction of travel point to point Lary
Nebraska Cowman
12-12-2003 05:17:43
just measure straight across the beams, from the side of on to the same side of the next.
jc
12-12-2003 07:14:32
 Re: Re: How to measure a plow in reply to Nebraska Cowman, 12-12-2003 05:17:43
What about a single bottom plow?
JMS/MN
12-12-2003 09:50:40
 Re: Re: Re: How to measure a plow in reply to jc, 12-12-2003 07:14:32
Measure from the leading edge of the plow lay, at a right angle to it ,to the direction of travel, (if it throws the dirt to the right),to as far right as the plow lay cuts.
Joel Harman
12-12-2003 10:35:37
 Re: Re: Re: Re: How to measure a plow in reply to JMS/MN, 12-12-2003 09:50:40
Know what the share is? Know what the landside is? measure from the end of the share straight across to the landside
jc
12-22-2003 12:58:21
 Re: Re: Re: Re: Re: How to measure a plow in reply to Joel Harman, 12-12-2003 10:35:37
Thanks
