Corn Picker Elevator
CJ
12-09-2003 16:14:15
I live in Northern Colorado and am looking for an elevator 6-8 inches wide by 9-10 feet long for a project I'm working on. The best one I can think of is the "wagon elevator" off a corn picker. I'm having trouble finding one close by, so any help would be appreciated, or any other ideas for an elevator that size. Thanks.
Rick
12-11-2003 06:15:21
 Re: Corn Picker Elevator in reply to CJ, 12-09-2003 16:14:15
Chris; You need to go to a belt system. Soil in the return elevators wil be back peddley till it will finally plug it. You can still use the elevator,but eliminate the cchain paddle and put a belt in the unit, or even mount the belt to the chain paddles. that is already their. It will have to be cupped on top side though. How long unit do you need. I have a unit that will go under semi trucks for sale. Rick
CJ
12-11-2003 08:38:39
 Re: Re: Corn Picker Elevator in reply to Rick, 12-11-2003 06:15:21
9-10 feet is what I am looking for, but I can shorten just about anything.
ChrisL
12-10-2003 18:10:43
dirt moving will take a lot of power - have u considered an old gutter manure cleaner from a dairy or someplace they are made for it
CJ
12-10-2003 19:41:51
 Re: Re: Corn Picker Elevator in reply to ChrisL, 12-10-2003 18:10:43
Dirt is probably a little to loose a term. I'm actually going to move aerification cores from turfgrass. They are about 3-4"long by about 1/2" diameter.
John R
12-10-2003 15:32:56
If you are moving damp soil, the best way is to use a belt conveyor. The soil will really build-up on a corn elevator, and take a lot more power to move.
larry
12-10-2003 04:29:49
would an auger as in a mixer mill work? Also if you have a chopper box with a chain unload
CJ
12-10-2003 11:29:16
 Re: Re: Corn Picker Elevator in reply to larry, 12-10-2003 04:29:49
I'm going to be moving a damp soil mixture so I'm afraid an auger is going to plug. By chopper box do you mean a feed grinder, stalk chopper, or what? I'm unfamiliar with that machine.
JMS/MN
12-09-2003 19:26:01
You could make your own using three 1x8 pine boards in an H pattern, buy single flat chain with links for attaching paddles, and mount your steel drive and boot ends onto the boards.
CJ
12-09-2003 21:13:23
 Re: Re: Corn Picker Elevator in reply to JMS/MN, 12-09-2003 19:26:01
Good thought, thanks.
ChrisL
12-09-2003 19:10:23
I have an old old elevator u can have - southeastern south dakota - all the old elevators into the granaries around gere are only about 8 inches wide - this one os probably 35 feet long or so - take a chunk out
CJ
12-09-2003 21:07:38
 Re: Re: Corn Picker Elevator in reply to ChrisL, 12-09-2003 19:10:23
I'm originally from the Irene,SD area and was there last month, I should have looked around and found one before I left, rather than thinking I could get one here. Not many of the farmers around here handled ear corn. I'll keep it in mind. Thanks
paul
12-09-2003 17:55:42
Can it be closed, or open all the way? a clean grain or return elevator from a bigger combine might work if it can be closed.
--->Paul
CJ
12-09-2003 21:11:33
 Re: Re: Corn Picker Elevator in reply to paul, 12-09-2003 17:55:42
Either open or closed will work. There are quite a few old combines in my area, any thoughts on specific makes or models, or will they all have similar elevators in them?
paul
12-10-2003 13:45:50
 Re: Re: Re: Corn Picker Elevator in reply to CJ, 12-09-2003 21:11:33
Also, the dairy & livestock industry uses a lot of those to move silage & feed into TMR mixers. They are already stand alone with electric motor, heck you could spend crazy money & buy a new one, but could find something that was taken out at a dairy/cattle center that does installations????
--->Paul
