Can't resist this question
Jim C.
12-08-2003 23:12:20
I have quite a bit of old hay machinery, grew up using old stuff and have a good collection of old hay equipment catalogs.
One thing I have never used and have never seen is what was called a "hay loader". These machines were wheel driven and were attached to the rear of a hay wagon. As the horses pulled the wagon the loader would scoop up the hay from the windrow and, through a series of teeth bars that were driven from a crank, would shove the hay up 8 - 10 feet, over the top ag onto the wagon where some fortunate person pitch forked the hay evenly on the wagon making a stack.
My questions, are there any of these still out there? How well did they work?
Just curious.
pendejo
06-18-2006 20:53:19
 Re: Can't resist this question in reply to Jim C., 12-08-2003 23:12:20
i am in the process of restoring a loose hay elvator/ haybuck i will have photos of it soon i have tested it it can move hay to me faster than i can move it to the front of the wagon
farmerjohn
12-12-2003 20:57:55
We have a New Idea one at the home farm, has not been used since 1962 has never been left outside. About 1980 we traded our John Deere 12A combine in on a JD 40 self propelled and the hay loader was also to be traded in, the dealer didn't have room on the truck for the hay loader and said he would come back for it--he never returned. I never saw it out of the wagonshed except ten years ago I took it out a couple days to re-do the floor.
rustyfarmall
12-10-2003 05:58:46
I don't know where you live, but the annual Carsten's Farm Days show in Shelby, Iowa demonstrates one of these every year. Very interesting to watch.
Leroy
12-09-2003 18:29:49
Some of the Amish here in Ohio and Indiana still use them
Frank
12-09-2003 16:44:47
You're right, I can't resist this one. I also grew up using the hay loader, even though I'm not as old as most who are familiar with them. Instead of using the forks mentioned, our loads were built in 3 layers, separated by "slings,(made of rope with two wooden slats across to keep the ropes about 3-4 feet apart. The ropes came to a single point at each end and would be hung over the ends of the wagon for attachment to the rope lift in the barn. The slings were laid out, one to hte rear and one to the front, with a quick trip device in the center. At the barn the slings were hauled to the peak by a tractor running out the barn door, then moved by another rope and pulley assembly, via the "hay car" that travelled the track along the peak. At the mow (my end) the sling load resembled a large round bale of "loose" hay, and you would gently start to swing it back and forth in the mow until it hovered for a moment over the spot where you wanted it to land. At that moment you gave a sharp jerk on the trip rope and the slings would separate and drop the load. There was still plenty of pitchfork application. Born in 1900, my Dad was frugal and we were not on the cutting edge of farm tech, so we used the slings and hay loader until after I was out of college and not available to help. (1965, when Dad was 65)It was a talent to build a load that big on hilly ground, and a point of pride to him. Hay wasn't bad, but a 3 sling load of slippery oat straw took a master's touch. There was only one way to get it back on if you lost it. The hard way. Regarding the hayloaders, I think ours was a McCormick, had the small dolly wheels in the rear. JD had a front wheel assembly that made them more stable. When not in use we had to tip ours down to lessen the wind surface. If interested, I wrote an article called "Chores" that is at the bottom of the "miscellaneous" category of the article archives on this site. More about the early years. Sorry about the length. FJY
Tim(nj)
12-09-2003 15:12:09
A couple of years ago I was at an auction where there was a JD 4020 tractor, a 6600 combine, and all the other equipment that you would expect on a dairy farm, most from the late '60s era. I did not see a baler, though. Figured it had been sold before the owner had passed on. Then I noticed that the 3 New Holland running gears had hay racks on the back and the front of the wagon, none on the sides. Odd, thought I. Then I walked around the corner and saw it. A New Idea raker-type hay loader, ready to go to the field. This guy had been putting up loose hay to feed his dairy cows right into the early '80s! He had converted to modern (for the '60s anyway) tillage, planting, silage, and grain equipment, but for some reason still used that hay loader. The mow in the bank-style dairy barn was the kind you could drive through end to end. Big arched roof with the hay trolley overhead. Somebody who hobby farms with Belgians bought the loader for $300.
Bob
12-09-2003 15:03:42
I have one... It's a "Minnesota", made at the State Prison. Works like Jack the Bear, but it's a man-killer to pull the hay away from it, and spread it around the hay rack, and pack it down!
Charlie
12-09-2003 14:57:44
I have an IH one I play with a bit in the fall. I'll cut a few rows with my horse drawn mower, dry it for what I can for late in the year and feed it off the the wagon to my beef cow when I have one. It saves me a month of feeding bales and its one more play toy in the back yard.
Haas
12-09-2003 14:41:56
One of the first tractor driving jobs I had was driving the Farmall Super A pulling the wagon with Hay Loader behind. As others said, the hay loaders will clean up a wind row as good as any hay baler. We never had any trouble with the one we had, but it was sold I think shortly after I got to tractor driving age and we converted to bales.
greenbeanman
12-09-2003 11:00:57
I've enjoyed all of the stories on the hay loader.
Thanks Hugh and others.
Just from looking at them, they look like they would go in front of the wagon and bring the hay up and over. I noticed someone said they fasten to the back of the wagon. Is that correct? Seems backwards, but I suppose quite possible since I've never seen one in operation.
In answer to your question, I'm writing this on Tuesday, and there is one currently listed on Ebay. It doesn't yet have a bid, with the bid starting at $200. Has been stored inside according to listing information.
Hugh MacKay
12-09-2003 14:18:37
 Re: Re: Can't resist this question in reply to greenbeanman, 12-09-2003 11:00:57
greenbeanman: The loader did indeed hitch behind the wagon. That was part of the speed of it, when you finished the load you just pulled pin on loader. The one we had just had a hinged hook on loader tongue and a ring on back of wagon for hook.
greenbeanman
12-10-2003 12:30:08
 Re: Re: Re: Can't resist this question in reply to Hugh MacKay, 12-09-2003 14:18:37
Thanks for answering. They really sound like a neat way of putting up loose hay. Expect I might have to get somone to drive the tractor for me to be really productive though.
Chris Brown
12-09-2003 10:22:55
I live amongst a small amish comunity here in northeast missouri., they still use these loose hay loaders although some have gone to a gas engine powered square baler.
J Kirsch NY
12-09-2003 09:32:08
We had a Keystone hayloader, the type with a rope & wood slatted apron. One day the front dolly wheels broke loose and the loader pitched forward onto my cousin. Fortunately he wasn't hurt badly. John in NY
G.King
12-09-2003 08:25:42
Enjoyed your story.I loaded one load with a hay loader. i was on load ,Don't rember Why, as Father in law had a baler then ,
Hugh MacKay
12-09-2003 06:27:18
Jim: My first job as an 8 year old on the farm was driving W4 with 16' wagon pulling hayloader. My dad used the crank and push bar type loader. I remember I was placed in this job as my grandfather then in his early 70's was getting a bit rough on his clutch performance. Hired help on wagon were complaining. I remember, I was told to do as men on wagon instructed and not to knock anyone off the load. Most of the time you ran in 1st or 2nd gear. With side delivery raking these machines would clean the field as well as any modern day baler. I do know that with the W4 and the loader we had you could bury the two men on load, this often made it necessary to stop.
Our system was based on a track pitching device at barn, which my dad operated along with two teenagers. one to drive the horse and other to set fork on load. My dad worked the hay mow or loft.
In the field, I remember one of the hired men and myself got to sit in the shade of the hayloader, while the other guy took load to barn with W4 and returned with an empty wagon. I can remember these guys building loads of loose hay on an 8' by 16' wagon that would just fit through a 12'x12' door. I can remember a few time the top layer of the load being slid off the back af wagon as it went through the door. There were always guys in a community who had a reputation of being able to build a load of loose hay that wouldn't fall off on way to barn. Some of these guys could build a load twice width of wagon. I remember anything over 15 loads being a good day on a dairy farm with milking to do. I'm thinking we probably got a couple ton on most loads.
Those were the good old days. Before we got a baler I did graduate to being one of the guys on load for a year or two. I remember thinking how great it would be to work on a hay crew using a baler. You know something, baler just caused you to work harder. My dad claimed and I agree baler didn't improve a thing until the thrower, or bale basket. Working on a smooth deck of a wagon behind a baler was no picnic. It was a lot easier to stay on your feet on that load of loose hay. Baling hay on ground and picking up later was a step backwards. Yes, one thing is certain, that old hayloader did a very efficient job of picking up hay. My dad's first baler was a IH 45, it didn't increase productivity. We almost parked it and went back to hayloader.
Speaking of building loads of hay, I remember an old guy in my home town, who farmed in middle of village. He had sold a lot of his land to housing, but still kept a few cows. He had all his land in pasture. His hay source was back end of all the lots he had sold. He mowed with sythe, worked the hay with fork. He hauled the hay home on a wheel barrow about 3' wide by 5'long. He could put a load of hay on that wheelbarrow that filled one lane of town streets. Caution had to be used in passing him, as you often could not see traffic coming other way.
Mike (WA)
12-09-2003 12:26:26
 Re: Re: Can't resist this question in reply to Hugh MacKay, 12-09-2003 06:27:18
I remember into the late '60's, an old gentleman in the Centralia, Washington area used to rake and haul home the "hay" cut by the state highway mower within the interchange of Interstate 5 in downtown Centralia. He had an old horse and wagon that he hauled it home on. Of course he had no right to do it, but no one had the nerve to tell him. The last couple of years, a local officer would quietly pull in behind him to control traffic behind him as he made his way home with his load. Kind of miss the old guy.
Hugh MacKay
12-09-2003 14:11:40
 Re: Re: Re: Can't resist this question in reply to Mike (WA), 12-09-2003 12:26:26
Mike: To bad we still didn't have a few of those old guys going around making hay in those small corners. We wouldn't have so many weed breeding grounds.
Kelly C
12-11-2003 06:01:06
 Re: Re: Re: Re: Can't resist this question in reply to Hugh MacKay, 12-09-2003 14:11:40
That is one thing I rememeber about being in Korea. You wont find 1 foot of airable land that does not have some crop growing in it.
I remember driving my duece along one of the main hwy from Seoul to camp Casey. Every corner and median had cabbage growing in it.
Oh and I remember that smell....pew....
Aaron
12-09-2003 05:42:57
My great grandpa and great uncle put up enough hay for 30 dairy cows with two teams of Clydsdale horses up until the mid 1980's. They had several hay loaders and wagons, and could haul a lot of hay in a day that way. Used one single horse to pull the hay into the haymow with the forks and track system in the peak of the barn roof. Now it's just my uncle left, but he still cuts all his hay with a MN#4 mower and horses, rakes it with a Farmhand 5-wheel rake and horses, and bales it with a WD Allis Chalmers and a Roto-Baler. That's enough hay for 20+ beef cows and several horses.
Hugh MacKay
12-09-2003 14:07:49
 Re: Re: Can't resist this question in reply to Aaron, 12-09-2003 05:42:57
Aaron: Do you have any photos of the clydesdales on the wagon and hayloader. That would be a sight to see. I know of a commercial dairy farm, milking 50-60 cows and doing all round bales. The senior partner in the family, hauls all the round bales to the barn with a wagon and a team of clydesdales. When he goes to field he has team trained to follow him, he with front end loader. He claims still most economical way to move hay off field.
I have a photo I should get scanned, beautiful picture of several teams at a plow day. Tractors were all tied up threshing the grain that day. They were using 3 horse hitch on the binder.
larry
12-10-2003 05:09:24
 Re: Re: Re: Can't resist this question in reply to Hugh MacKay, 12-09-2003 14:07:49
your talk of training horse to follow reminded me of a story about one of my uncles he delivered milk in detriot he would stop at one house and deliver milk and the horses would go ahead and wait for him at the next stop so much for dumb animals
Hugh MacKay
12-10-2003 06:20:11
 Re: Re: Re: Re: Can't resist this question in reply to larry, 12-10-2003 05:09:24
Larry: I remember one time dad giving a lecture on drinking and driving. He being suspecious some of his 5 sons may be partaking in this exercise. He advised this was much different in the olden days. He reminded us of an old neighbor, who let his hair down about 4 times a year, went to town with horse and wagon. While in town some 20 miles away from home he would get quite intoxicated. His friends would load him in the wagon, point the horse for home. By sunrise next day Bill was always in the back yard and no one had been endangered. I somehow cant imagion Bill's head didn't feel worse, lieing down in a steel tire wagon over 20 miles of gravel rosd.
Joel Harman
12-09-2003 05:10:02
They work fine if you have flat ground & desire to put your hay up loose.
Nebraska Cowman
12-09-2003 04:35:19
I remember them. Granddad had a Case Loader. That is the style with slats and rope. Would love to have one restored but they are not found much here. Most were stored outside and rusted down years ago.
Charley
12-09-2003 08:32:28
 Re: Re: Can't resist this question in reply to Nebraska Cowman, 12-09-2003 04:35:19
Here in southern Missouri you see a hay loader occassionally. Most were IHC and have been left in the weather for years. Probably take some effort to get them to work. Sometimes the tin isn't too bad since the rain didn't have a flat place to accumulate.
JB
12-10-2003 19:08:40
 Re: Re: Re: Can't resist this question in reply to Charley, 12-09-2003 08:32:28
We had an IHC until we bought a NH forage harvester in 1952. Uncle had a different model that used a crank & pusher sticks. He used horses to pull his wagon and would tie the lines to the front of the wagon and horses would follow the windrow and my uncle would build the load. The same at the barn with the hay fork, he would just yell instructions to them and he would work the hay fork on top of the wagon.
No one mention how hard it was to get that loose hay out of the mow. Used hay knife to slice through the long hay.
JB
