Minneapolis Moline Baler Parts
Jim C.
12-08-2003 23:02:11
I am searching for a hard to find part.
I need the v belt that runs off of the flywheel to the sheave.
The baler is a mid 1950's MM 760 Bale Master, The part number is 15A16127 and the belt is 99 5/8" O.C.
Anybody out there that can help will be appreciated!
paul
12-09-2003 20:51:51
 Re: Minneapolis Moline Baler Parts in reply to Jim C., 12-08-2003 23:02:11
There is a company called Jay Dee that has most any V belt available, & have a large web data base of ag part number references. Sorry I don't have their web page handy, but you should be able to track it down. I have no connection to them, other than ordered belts once & seemed a good deal.
--->Paul
Roger
12-09-2003 15:34:31
You might try an Oil Field Supply store. You will
have to have the belt with you or a very close
mearurment. The belts used to run pump jacks are
made better. I used to run Gleaner combines with
bonded belts. I found that indutrial belt only
cost 1/3 as much as a belt from AC, but would last
4 times longer.
