furrow makers
RandyNcal
12-08-2003 14:40:53
OK it's me again, I have checked all the archives and can't find anything on what yall use to make furrows. On the job I have used a rolling cultivator in the past to make furrows and cultivate at the same time. Now that I will be on my own with just an 8n and H I need something on the small size. Has anyone tried adapting rolling cultivators for one row or two, or what do you guys do I want to raise sweetcorn.
John A
12-09-2003 17:06:31
 Re: furrow makers in reply to RandyNcal, 12-08-2003 14:40:53
Randy, In the Texas/Okla. panhandle We call what you are talking about ..... Listing ! The implement is a toolbar that has a given # of standards on it , on each standard is a Middlebuster sweep. IE, 5 sweeps will give you 4 matched tops/bottoms, depending on where you are planting.
Hope this helps,
John A.
RandyNcal
12-09-2003 12:01:34
Sorry, maybe different for yall but here in cal or ( Terminator land ) as we now call it. We make our hills or seed beds first because water is precious and scarce, we then pre-irrigate to get the moisture down so that when we plant the seed will germinate. This hilling or seed bed making is what we call "furrowing out the ground". I am preparing to move to Arky so I need to know the correct way yall do it, I have 8n and H Farmall. thanks for your help
paul
12-09-2003 17:51:15
 Re: Re: furrow makers in reply to RandyNcal, 12-09-2003 12:01:34
Up here in Minnesota, it's so darn wet we have a heck of a time getting seed in the ground in spring - all the snow melt & spring rains. Can't help you with your situation I'm afraid, we do anything we can to dry the ground out 8 out of 10 years.....
--->Paul
Tim(nj)
12-08-2003 17:24:25
Are you making furrows between rows of growing corn, to catch water? Hilling up the corn to kill weeds in the row? Lilliston made (also sold by A-C) a 2-row rolling cultivator that would work on a smaller tractor. You can also get rolling cultivator spider-wheel assemblies from Agri-Supply that you can mount on your own toolbar.
paul
12-08-2003 15:53:49
I'm sure others will not be as dense as I am, but I use a corn planter for planting corn in rows.
Are you looking to make shallow trenches down a field and then drop the corn in by hand? Sorry I don't understand. A furrow is something a plow makes, but I can tell that isn't what you want.
Would a small 3-point field cultivator with just a shovel per row be what you are looking for?
--->Paul
