JD D engine
Bill Hayes
12-08-2003 09:40:42
I looked at a styled JD "D" recently that is for sale. It has been stored inside and has not run for 35 years. The engine is free, TO A POINT....the flywheel can only be turned about 1/4 of a revolution forward and backwards !! The owner advises that the flywheel was cracked and came loose while running. It was shut down and that was the last time it ran. Just above and forward of the flywheel is a large (3/4") bolt end, castlated nut and cotterpin exposed on the outside of the crankcase. As the flywheel is turned for and aft mechanical noises can be heard internally and this nut and bolt assembly wobble around. I am not familiar with the internal parts and workings of this engine and I have not yet studied a parts catolog, but can this situation be indicative of internal problems as a result of or prior to the flywheel coming loose ??? Any ideas would be greatly appreciated as this tractor is in most excellent condition otherwise.
Thanks....Bill
