I got a 100 gal Demco model years ago with a 20' boom & wand. Was nice to hook up & use it. But, you could build cheaper, if you are handy with that sort of thing. I agree on the plastic tank. We tend to use 10-20 gallons per acre for good coverage & mixing, Decide on how big you want, 50 gallons would be fine, you probably can use a 100 gallon if you wieght your front end at all. If you have alfalfa or clover, that is DIFFICULT to find a spray solution to weed problems. If it is all grass hay, then you want a broadleaf spray. Different ones handle different weeds better or worse. The real good ones that really kill off the bad weeds are costly. On the other hand, 2,4D is very cheap & kills or supresses most broadleaves. I'd ask for local advise on what works well for the weeds you have. Mostly you end up buying 2 gallon jugs of chemicals, and can use as little as 4 oz per acre (up to a quart for the cheaper ones), so you might be shocked at the outlay, esp. if you are only covering a few acres every year. Some chemicals do require you pass a course & recieve a licence to spray, different states are slightly different on that. And you are liable, if a neighbor has a garden nearby, understand drift & all that. :) --->Paul
