dual purpose mower
RandyNcal
12-05-2003 09:28:02
Hi guys it's me again, thanks for all your help in the past and again here's another stupid question. I am running my farmall H with a pull type bush hog for my pasture and it works great. I would like to mount a woods finish belly mower to do my front yard, about 2 acres of burmuda, I have heard through this forum that this is a good finish mower but also understand hard to mount and un mount. Here's my question is it possible to mount belly mower and still be able, by maybe disconnecting a belt or something, to use my bush hog then when finished re-connect belt and mow front yard? I'm getting older and would like something easy. Thanks guys you have been a great help in the past.
rustyfarmall
12-05-2003 10:40:50
 Re: dual purpose mower in reply to RandyNcal, 12-05-2003 09:28:02
Easy solution here, just go out and buy another H, then you don't need to bother unhooking anything. Seriously, removing and reinstalling the drive belt for a Woods belly mower is not an easy, or quick thing to do, the belt has to be installed just perfect or it will not stay on, plus the drive pulley which is installed on the pto shaft is not intended to be taken off and put back on, it's kind of a hassle also.
