belly blade on Super A
kevin
12-03-2003 21:36:19
I was curious if anyone had any photos of a Belly blade mounted on a Super A. I have the blade but am not quite sure how it is mounted on. Any information is helpful.
Thanks.
Taylor Lambert
12-05-2003 10:27:20
 Re: belly blade on Super A in reply to kevin, 12-03-2003 21:36:19
ON my cub the blade can mount on the front or middle. to mid mount it turn the draw bar around backwards and mount it in the fron set onf holes on the final drives then the blade shuond have a pivot on the end of it bolted to a U shped part the U shped part is for the front mounting unbolt it and the 2 bolt holes they should match the holes in the drawbar. THen use a chain or springloaded culitivator rod to hook into the ttop of the blade. this may be different on the Super A The midmount blade it great on driveways becaus the blade is in the middle like a grader.
