Farmhand loader pressure
Fudd@work
12-01-2003 18:02:52
At work we have an old Farmall M with a Farmhand loader. We purchased a new PTO pump for it and I was wondering what I should set the pressure relief at. My way of thinking is 1500 PSI at full throttle. Any ideas what the original pressure might have been? I put new piston seals on the cylinders a couple of years ago. Thanks.
Kennyp
12-02-2003 06:02:09
 Re: Farmhand loader pressure in reply to Fudd@work, 12-01-2003 18:02:52
Pretty sure those old PTO pumps were more like 1000 lb/sq in. I could be wrong though.
JMS/MN
12-01-2003 21:49:17
Farmall used to be at a low pressure- like around 1500. AC and Ford were at high pressure in those days- 2200-3200.
JMS/MN
12-01-2003 22:54:10
 Re: Re: Farmhand loader pressure in reply to JMS/MN, 12-01-2003 21:49:17
1500 is the lowest pressure that I've ever heard of for any hydraulic system, so it should be safe to start there. If it works at that pressure, I would leave it there. Also, years ago, didn't many Farmhand loaders have their own PTO pump system? Good chance that the cylinders were low pressure.
Grewolf
12-02-2003 06:54:18
 Re: Re: Re: Farmhand loader pressure in reply to JMS/MN, 12-01-2003 22:54:10
I still use a FH loader. Has it's own PTO pump, I think Prince is the common one used at least now.
Pretty sure it's low pressure, just galvinized pipe going up the frame to the bucket cylinders and loader rams. Hose is at the ends for making the bends.
