Massey Harris #510 ONE-WAY DISC
John
11-29-2003 18:17:01
Purchased this implement last year and when using it, found that when i pulled the lever to trip/ lift the discs from the ground, it would take about 100' before the ROTO-LIFT would kick in, and the discs lift. According to the info I got,when tripped, the discs should clear the ground in two feet of travel and to full transport position in 40".
This summer I disassembled the lift system, which has 4 levers within it, as well as 4 springs and 4 rollers. I had a machine shop go over the lift mechanism and make/repair what ever parts were worn. I reassembled the power wheel clutch back onto the one way disc and am still having the same problem. Does any one know if there is something else I should be looking at? Not sure how this roto-system works, can anybody explain it to me. Thanks for any replies.
