Wood Splitter MF 360
TDK
11-28-2003 17:45:08
Hooked up wood splitter to MF 360 remotes.Cyl. will only move about 3 inches and will not return no matter which position hyd.controls are latched.This same splitter works on an IH 504& 484.Somebody please help!!!!! !!!!!
jason
11-29-2003 19:32:25
 Re: Wood Splitter MF 360 in reply to TDK, 11-28-2003 17:45:08
is this a case of open center vs closed center? On out Metavik (sp) log forwarder there is a special plug on the forwarder's controls that has to be switched when going from ford (open) to John deere (closed) . The forwarder (log graple and trailer combo) is hooked up to the tractor;s hydralics and the tractors lever is left on, the rest is controled by the levers on the forwarder.
Bob
11-28-2003 20:45:13
Perhaps you have a mismatch of hydraulic coupler tips, and one or both are not engaging completely, or one of the tips does not have it's check valve depressed.
