JC, This is interesting. Why was the ground abused? Is it good tillable soil, otherwise? Dryland, I'm assuming? It is kind of hard to talk about this without seeing your dirt. :>) Talking blind & assuming you have decent soil, I think I'd gamble and hit this guy with both barrels right off the bat. If you wait until 05 to plant the alfalfa, you are not going to see a substantial crop until 06; that's two years away! If it were mine, I think I'd plow it early next spring after the thaw and I'd plow it deep or hit it with a one-way. Trouble is, oats will not do well in loose soil, as you already know. So, why not go back in and hit it with a packer and plant your oats with a close-spaced 7" drill while planting the alfalfa at the same time using a good heavier than normal rate? With any luck (and rain), the oats will cover quickly and help to fight your weed problem. If not, you still can drop the oats earlier next season and hay it, with that new alfalfa crop coming in behind. If the rains come in right, you might even get the first cutting of alfalfa off next fall. Bottom line is: at the tail end of next year, you should have your alfalfa crop established. I wouldn't waste a whole year just fighting the weeds. I'm just an old man talking to hear myself talk, and whatever you do, I hope you well. You Kansas boys are some kick-ass farmers, know about small grains and how they work; and whatever you decide, I'm sure it will work out. Allan
