New Holland 400-440 hay crusher
Sighombre
07-18-1999 21:11:46
I was given a NH 400-440 model hay crusher this weekend. It needs a a new bearing on the end of one of the rubber rollers. Is this part available at a NH dealer and how do I go about replacing it?
Thank you.
Ernie Dankert
07-19-1999 16:05:43
 Re: New Holland 400-440 hay crusher in reply to Sighombre, 07-18-1999 21:11:46
Replace all the bearings while you have it apart. Take the old bearings to any bearing shop and match them up. here in New York I recommend Syracuse bearing. Bearings will spin on the shaft and wear a groove when they fail. We had that happen once and put the whole roller on lathe and cut it down for a bushing. Check the springs/bolts on the slip clutch. Broken bolts will cause the clutch to slip and the machine to plug easily
