When to use side hill Combine?
Michael
11-24-2003 12:00:55
I've seen plenty of regular combines and a few side hill models.
How hilly does a farm need to be before you switch to a side hill model?
Joel Harman
11-25-2003 19:50:37
 Re: When to use side hill Combine? in reply to Michael, 11-24-2003 12:00:55
When your hind end doesn't have enough pucker to keep you in the seat. Probably after you get past 10%.
Rick
11-24-2003 17:00:52
I use sidehill all time,the heads follow the ground alot nice than regular machines. The new one now have contour master which is suppose to help in that department now. I like the sidehill machine.
Bob G
11-25-2003 06:39:24
 Re: Re: When to use side hill Combine? in reply to Rick, 11-24-2003 17:00:52
I live in eastern Washington state, which has some very steep slopes. Side hill combines are used everywhere even on the level ground. I attached a photo of a shot of a sidehill behind our house.
Bob
Link
Nebraska Cowman
11-26-2003 04:18:49
 Re: Re: Re: When to use side hill Combine? in reply to Bob G, 11-25-2003 06:39:24
must be differnt dirt than we have here or would be gullies washed in it
Allan
11-25-2003 09:23:28
Bob,
WOW!!
I would think that in your country, you absolutely "have" to have those types of machines, right?
Allan
jls
11-25-2003 19:30:47
 Re: Re: Re: Re: When to use side hill Combine? in reply to Allan, 11-25-2003 09:23:28
have run regular combines on short slopes like that, up the slope circle the field down the shallow slope and back up the steep head first.Always told go to sidehill when slope affects how the crop moves across the straw walkers and pans. Don't know if slope would bother rotarys.
Bob G
11-26-2003 07:31:26
 Re: Re: Re: Re: Re: When to use side hill Combine? in reply to jls, 11-25-2003 19:30:47
They used to mold board plow all this ground. When I moved here you would see washes 2 to 3 feet wide and that deep. They have upto 15 of top soil, estimates are they loose 1 bushel of soil for every bushel of crop. Some locations have proven yields of 120 bushel on dryland. I have seen combines running at a 45 degree angle when combining on the contour. Most of the farmers still use crawlers because they have trouble keeping 4 wheel drives on the hill. Most of the new combines are too heavy to keep on the slopes so they use JD 6622 and 7722 or IH 1460 and 1480.
Bob
