NH469 Haybine
FordFarming
11-24-2003 09:46:48
I have a NH469 haybine and was just wondering how many of you guys have had to rebuild the drawbar on your machine. I was also wondering if anybody had an idea on what could be causing grass to ball up on the cutting bar. It's a new knife with 1 season (about 10 acres) of use.
Thx.
Big Jim
11-25-2003 10:59:48
 Re: NH469 Haybine in reply to FordFarming, 11-24-2003 09:46:48
In addition to the guards, your cutter bar(the plate where the guards bolt to) could be bent. This could also cause the hay to build up between the guards and the cutter bar. Get down on your hands and knees and look down over the guards from one end. If the line of guards is wavy looking, then you have either bent guards and/or a bent cutter bar. Start by replacing the guards first. If this does not significantly straighten out the line of guards, then your cutter bar is bent also. You can straighten this also. If you still need help after replacing guards, post back and will explain how to straighten a cutter bar.
Jimmy King
11-24-2003 19:47:33
How are your guards they are just as importion as the sickle. My last 495 when I traded for it used I got new sickle and guards in the deal mowed about 2500 acres before I had to pull the sickle and sharpen it thats not bad in these SW Mo. rocks.
norbert kanzler
11-24-2003 10:06:49
Adjust your guards. follow instructions in owner's manual
