JD 290 corn planter -operation info needed
Richard Rinard
11-22-2003 19:54:05
We recently bought a JD 290 two row trailer type corn planter in excellant shape. A few hours with a wire brush and a paint brush and it looks like new.
The planter came with 7 sets of plastic seed plates. JD only has specs on the OEM metal plates.
The plates that came with the machine are made of plastic and appear to be color coded. plates have part numbers but no MFG info so i can not find the specs to determine what seeds to match with the plates. can anyone tell me how to measure the plates or perhaps who may be making plastic after market plates?
The is also a small hopper mounted midline and a bit above the fertilizer hoppers. It has a screen in the bottom and a chain driven despensing rotor.
There originally was a decal on that hopper that warned of handling chemicals so i assume this hopper is intended for pesticide.
i have been toying with the idea of mixing very small seeds like beets and carrots with sand and dispensing through the pesticide hopper,
we are a very small farm (60 acres) and just in the intitial startup phase so we intend to do a lot of truck gardening to get some cash flow while we work towards acquiring haymaking equipment. if this idea will work i think i could use it to plant beets,carrots,collard and mustard greens. Can anyone offer any advice on this idea?
Jason
11-23-2003 16:33:06
 Re: JD 290 corn planter -operation info needed in reply to Richard Rinard, 11-22-2003 19:54:05
lincolnagproducts . com will help a lot, they sell plastic plates with the color coding your talking about ( cheaper than JD ). What does your owners manual say about the pest applicators? I also have a 290 but my manual is at the farm and I don't have the pest applicators J
Tom Brown
11-23-2003 04:23:03
I've used a JD 494 planter for 9-10 yrs. The seed plates with the rectanular cells are fordifferant sizes of feild corn. The plates with roundish cells are also for field corn, BUT they are the proper shape for sweet and indian corn. I use plates for sorghum to plant popcorn. How you determine wich plate to use is by judgement..... .. you take some seed and place it in the seed cells. You want to select a cell size that is just slightly larger than the seed. If the cell is too small, the seed will get stuck in the cell, and / or damaged. A cell too big will hold more than one seed and the seed spacing will be too heavy. The little box on top is probably the herbicide applicator. When that planter was made, granulated weed killer was applied on top of the soil behind the planter. I would be leary of using this box for seeding. No matter how much you clean it, it can still have some residue in it. The crops that you speak of are very succeptable to some of the old herbicides. Also, even mixed with sand, you would have very irratic stands. In the early years of veggie growing I tried some of what you speak of. Best bet is to buy a used Planet Jr. unit for about $100. It will do a much more accurate job and it can be used for a lot of differant veggie crops.
