Minneapolis Moline disk plow
Sean W
11-22-2003 11:52:08
I was wondering does anyone see the old one way MM disk plows anymore? I am looking for one, and I am in the wrong part of the country(NE) to find a disk plow. I am looking for one that is an 8' or 10'. I would like it to be that size, none smaller, plus if possible, to have it hydraulically lifted, otherwise the hand lift and/or power lift would work. Would like it to have all good blades if possible, and steel wheels(not rubber). Thanks!
JC
11-23-2003 11:21:14
 Re: Minneapolis Moline disk plow in reply to Sean W, 11-22-2003 11:52:08
I have seen several dozon sell at farm sales this fall in north central Kansas, most sell for iron price, about $35.00
I reccommend you search the web for upcoming farm auctions in wheat country, you will find just what you are looking for, be sure to bring a good trailer, as most ones I have seen are either on steel or had the tires rotted off of the rims.
Roger
11-23-2003 13:47:45
 Re: Re: Minneapolis Moline disk plow in reply to JC, 11-23-2003 11:21:14
Any oneway will bring more than $35.00 around
South Central Kansas. Farmers buy several oneways
and scrap them out. They put the blades on their
offset disks. It makes for cheap blades that are
heavy duty. They also have a lot of good iron left
to repair things with.
Roger
11-22-2003 11:58:28
Are you looking for a disk plow or a oneway? A one
way has all the disks on a common shaft. A Disk
Plow has each disk mounted on a seperate bearing
housing. I have both types. If you would like a
picture let me know. I do have one MM oneway I
would sell.
Sean W
11-22-2003 15:22:08
 Re: Re: Minneapolis Moline disk plow in reply to Roger, 11-22-2003 11:58:28
Yeah I wanted to find one that was a one way, with the disks all in a line. Where are you from and what is the size of it? Thanks!
