Don't mean to be a grouch with you. :) You are asking about starting farming & planting stuff. To me, the most important piece is the planter I guess. Can't possibly tell you what tractor to buy for your operation, without knowing what you plan to pull with the thing! No-till means different things to different people. No one in my whole county does real notill, I have to drive almost 100 miles to get to lighter, drier, warmer soils where it works somewhat. But people go to rippers & various chisel plow designs & call that no-till around here. Their fields look just as black as my plowed cornstalks which I don't shred or disk. So, I guess I'm just wondering what it is you want to do. From that, pick a planter & some minimal tillage equipment (for fixing problem areas, compaction, etc.). And then, at that point, figure out a tractor you need. Just hit me as funny, that you state you want to get into notill farming, you list the tractors you have, and you want to buy more tractors. But, what about the notill? What about the planting? felt like you forgot that. Yes, my reply & others were a little off the wall, not very helpful. Guess it was hard to be helpful when it looks like you are putting the cart before the horse, and I meant to be a little funny. Sorry if it didn't come out that way. Yes, you probably need more than a 300 to pull a real notill bean drill & real notill corn planter of any size. How big of equipment are you looking at? It would be easier to help you if we had some clues. Many folks around here want 2 row corn planters. Maybe you are like my neighbor with 100 acres, but he bought an 8 row planter because it was cheap - he plants the end rows and is almost done! ;) ;) Around here, IH 56 planters were ok, and the updated 800 air planters are acceptable. In between, everybody bought green for corn planters as well! :) But now adays, the Case machines have better depth wheels & closing systems for true no-till planting. Lots of people are swapping these red parts onto their green planters. Dawn & Martin & many other companies make add-on row sweeps/ coulters & closing wheels to retrofit planters to work in your soil types. It's not cheap per row, but without tillage, that planter needs to make a perfect seedbed in one shot, while spacing out corn in a perfect spacing on really tough damp ground. Need all the right equipment for your soil conditions. So again, we come back to the tractor - whatever pulls it, really. Least of my worries if I were going to try notill..... . ;) I've pulled my (regular tillage) corn planter with a narrow front mid 50's 40hp tractor, an 85 hp turbo tractor with cab, and a 27 hp compact little loader tractor. Doesn't much matter - the old tractor didn't have enough hyd to lift it full of fert, hate planting with a cab on, and the compact would be low on hp in wet conditions. The planter, however, matters. Seems odd you would shop for the tractor before knowing the planter is all. But, more tractors is a good thing - I have 7. :) --->Paul
