plowing 10 acres with a 2 bottom
Hootis
11-18-2003 19:59:55
I am new at this, Am I crazy to wnat to plow 10 +/- acres with a 2 bottom and a Ferguson 35 ?
Thanks for the advice
Rob
11-29-2003 19:24:17
 Re: plowing 10 acres with a 2 bottom in reply to Hootis, 11-18-2003 19:59:55
You aren't crazy, but persistance will be required for your project. You didn't say what plow but if you have 2 16s you will be covering 32 inches per through. It will take you about an hour per acre at that rate if you are doing 3 MPH. Sounds like heaven if you like plowing.
Haas
11-20-2003 16:23:47
I did not read what the others said, but No, you are not crazy. We always had IH stuff, but I can recall plowing 40 acres with a 2 bottom plow when I was a boy. I think it took several days.
treeboy
11-20-2003 16:05:48
i'm not sure if your mf35 has live power, but if you got an ORC HANGING on you pto shaft it will most likely hit the front coulter & do damage
JDMark
11-20-2003 10:07:35
I too am envious. I have an old 2-bottom & the only thing it's used for is to plow gardens.
Mark
Okla/kans Bill
11-20-2003 06:16:55
Ive plowed 12 or so every year here for nearly 20 yrs. I started with my Grandads 1934 CC Case, whichI still use, but not for plowing/discing, and went to what I now use, a 1937 F-30. I use a MC D 2 14, or my grandads 3 14 Case plow converted back to a 2 14. The 3 14 pulls harder in these sandy soils than they did up north. Well maybe not pulls harder, although aI did have some serious hard pan that id never ran into up north, but the tractors maybe dont get the same traction. I dont know. Course not being able to find somone handy to sharpen a plow share nowadays dosent help either. I plow , my main field is flat 10 acres. I plow in strips against a hill that rises on the East of the field. I plow N to S, in strips and back furrow up a ridge in a different place nearly every year to make tempory, yearly terrices.
Okla/kans Bill
11-20-2003 06:14:58
Dave Church
11-19-2003 19:07:22
third party image
Fifty years ago it was work. Today its fun
RayP(MI)
11-19-2003 16:47:35
Heck, we used to do 60 acres with a JD B and 2 12" plow!
Dave in Ohio
11-19-2003 16:17:57
Somewhere I once saw a book giving instructions for plowing. Laying out the field, dead furrows, headlands and the like. Any know about such a book.
Leroy
11-20-2003 18:45:39
 Re: Re: plowing 10 acres with a 2 bottom in reply to Dave in Ohio, 11-19-2003 16:17:57
That is in the older Ferguson Plow books
Roy in UK
11-19-2003 11:47:11
What about those guys who years ago plowed 10 acres with a single furrow behind two 'one h.p.' horses! Apparently for every acre they plowed they had to walk 12 miles.
Stu
11-19-2003 11:40:41
third party image
Your crazy not to, it will change your life. Get out there at shine that steel up.
rustyfarmall
11-19-2003 10:58:37
I am a bit envious of you, 10 whole acres? All I had to plow was a tiny little garden patch, I was done way too soon.
Stan TN
11-19-2003 21:14:14
 Re: Re: plowing 10 acres with a 2 bottom in reply to rustyfarmall, 11-19-2003 10:58:37
Get out your cub, the tractor you're usin' is too big. ;-)
tim[in]
11-19-2003 05:56:48
my big problem was probably plowing too deep and going too slow doing it. never did find too much of a hard pan.except on the ends occasionally. keep sharp shares and set coulters for what you are plowing. my grandfather farmed 40 acres with a 8n ford. i have plowed with a wd ,d17, 4010 jd,D-21 allis.farmall M,jd A.2-155 white and MM950and 8n ford. i'd rather use small equipment any day myself .good luck and be careful.
dkeller
11-19-2003 04:28:50
Around here we raise a lot of mint and it must be turned over in the fall. You may experiance a lot of wind errosion. One thing to consider anyway It may be better to wait until the ground is warm enough to germinate something to hold it
dan
Indydirtfarmer
11-19-2003 03:08:11
Yes you are! To remedy the situation, you should let ME plow that 10 (+-) acres for you. That is the most fun you can have on an old tractor! I'll go miles out of my way, to get the opportunity to plow anything! John
JMS/MN
11-19-2003 00:04:57
That was a normal days work when those plows were new-----enjoy!!
johndeeregene
11-18-2003 22:49:39
not at all sounds like fun to me except for the ford part. you will have alot of fun. get a friend to help with his antique an have a great day of having fun. we did 120 acres in 8 hrs this fall with 27 tractors
Fudd@work
11-18-2003 20:57:06
When I was a youngun, we plowed 100 acres with a 2-14 every spring:)
jdman(MO)
11-18-2003 21:37:50
 Re: Re: plowing 10 acres with a 2 bottom in reply to Fudd@work, 11-18-2003 20:57:06
My handy dandy chart says a 2-14 will plow 8.42 acres in a 10 hour day going 3 miles per hour. Russ
Dave in Ohio
11-19-2003 16:14:02
 Re: Re: Re: plowing 10 acres with a 2 bottom in reply to jdman(MO), 11-18-2003 21:37:50
You guys didn't know my Daddy. Ten hours in the Spring or Fall was just a good start. I have started on an old WD45 many days at 6:00AM, quit for dinner (lunch to you Yankees) and finished at 8:00PM. Just another day in my youth. Now I travel miles to plow with my 1952 JD AR and model 44-H plow and still love it.
Don-Wi
11-18-2003 20:27:07
Absolutely not!! Even if you don't have much experience, you will by the end of the feild. One suggestion, don't have a dead furrow every 20-50 feet, space it out a little more, easier to work over in the spring.
Donovan from Wisconsin
Tim TN
11-18-2003 20:59:03
 Re: Re: plowing 10 acres with a 2 bottom in reply to Don-Wi, 11-18-2003 20:27:07
My Dad an I used to to 40 with an 8N. Just get a good seat cushion, you're gonna be there for a while.
