JD 480 haybine opinions?
Josh
11-17-2003 06:30:59
I am looking for a haybine to cut about 25 acres of hay. I found a JD 480 in excellent condition for $350. I haven't seen many 480's around. Do they work well? Any known problems? Thanks for the advise.
Bob Semrau
11-18-2003 09:15:07
 Re: JD 480 haybine opinions? in reply to Josh, 11-17-2003 06:30:59
I also have used a 480 for 2 seasons now. I bought it for $150, and put another $300 or so fixing it up (that includes new tires). It has been a good machine for me. It isn't a speed demon, but is much faster than my 7 ft sickle bar and crimper were. The one weak point I know of is a splined coupler between the PTO shaft and the gearbox. Mine ground itself out when the sickle got stuck. I was able to find Deere's fix for this at a junkyard - a replacement for the coupler Deere called a shear-bolt assembly. You should look for that. I cut about 15 acres of hay a year, so this is about as expensive as I can justify. I would jump on one for $350 in good shape, if I were you.
Warren
11-18-2003 08:56:40
Josh,
I have a 480 (didn't think there were any others out there). I like it a lot. I bought mine cheap and I knew that the rolls were not too good. I bought it as a replacement for sickle mower. Mine works very well as a mower but doesn't crimp well. I just run a crimper after mowing and that works very well.
I have never had a problem with the rolls wrapping and I have been able to find replacement parts. I just put in a new sickle and it cuts great. The sickle is the same one as used in the newer JD mower - 1208, or 1209? Good luck with it if you get it. If you have any questions about it, email me.
Tim(nj)
11-17-2003 13:27:54
In my experience with one, they don't float over the ground that well, the conditioner rolls tend to wrap up on this machine more so than later models, and a lot of its parts are no longer available from Deere.
Bob Semrau
11-18-2003 09:22:58
 Re: Re: JD 480 haybine opinions? in reply to Tim(nj), 11-17-2003 13:27:54
I've only had wrapping problems when I was going to fast for it - I usually have it in first gear direct behind my Oliver 1600. I only go to second in very light hay. I haven't had much trouble with parts, either. You can get the sickles and teeth from Deere, and I am lucky enough to be relatively close to Stamm Equipment (Wayland, MI), which has a couple of carcasses.
Rick
11-17-2003 10:36:15
I have a REAL NICE JD 1460 disc mow/con $5950.oo. Just going to larger unit
Rick
11-17-2003 10:36:00
Jeff Jensen
02-07-2008 11:37:37
 Re: Re: JD 480 haybine opinions? in reply to Rick, 11-17-2003 10:36:00
I have one thats been sitting in the woods for some years. I am going to plow and seed the feilds this spring and wanted to get the 480 running again. I was wondering if anybody might have pictures of a 480 that is complete. I'm not sure if I am missing shrouds/ect. Its nice to know that others are still finding parts.
