Wheel bushing on a NH 256 rake
Bill B
11-13-2003 16:04:26
Hi, Has anyone replaced the wheel bushing? Is there anything I need to know to make it easier? Thanks, Bill
Steve from New Holland
11-14-2003 04:32:08
 Re: Wheel bushing on a NH 256 rake in reply to Bill B , 11-13-2003 16:04:26
Bill, you will find out when you go to get the bushing from your dealer that two different bushings were used. It does not depend on serial number. You will need to remove the wheel and check the o.d. size of the bushing. There are 2 bushings per wheel. Also, check the material of the bushing. Some are made of brass, part number 65930 and some are made of steel, part number 257702. The steel bushings are bigger o.d. than the brass bushings. By the way, they are not difficult to replace. Steve
paul
11-15-2003 00:34:45
 Re: Re: Wheel bushing on a NH 256 rake in reply to Steve from New Holland, 11-14-2003 04:32:08
Are the 55 rakes built different, my left wheel has a lot of wobble, but i don't see any bushing??? Should I?
--->Paul
11-15-2003 04:33:19
 Re: Re: Re: Wheel bushing on a NH 256 rake in reply to paul, 11-15-2003 00:34:45
Yes Paul, you should. They are the same as the brass bushing used in the 56 and 256 models. Part number 65930. Steve
