rebuilding a hydralic cylinder
Kelly C
11-13-2003 12:59:15
I Have cylinders on the bucket for my loader that is leaking all over the place.
How big of a deal is it to rebuild these or at least out new seals in them?
Cylinder
11-14-2003 17:20:59
 Re: rebuilding a hydralic cylinder in reply to Kelly C, 11-13-2003 12:59:15
May get in trouble for suggesting this but you might try some motor stop leak in there before you tear them down. I have used it in a old m farmall with no. 30 loader and it has stopped the leaks. It will soften the o rings and make them seal better. Buy the little better brand. 4 or 5 dollars at wally world. This has stopped leaks on hydralic cylinders also.
Bob H nw Oh
11-13-2003 17:18:23
Hey Kelly,Sent one message,musta got lost in cyber space!!I rebuilt cyls on my Case backhoe,not too difficult,what loader you got,maybe post a pic,Bob.
Kelly C
11-13-2003 17:42:18
 Re: Re: rebuilding a hydralic cylinder in reply to Bob H nw Oh, 11-13-2003 17:18:23
third party image
Its the ones on the bucket.
I can get some close ups tomorow if that helps.
Bob H nw Oh
11-14-2003 14:50:53
 Re: Re: Re: rebuilding a hydralic cylinder in reply to Kelly C, 11-13-2003 17:42:18
Hi Kelly,hard to tell from pic,looks like they have a threaded gland nut to unscrew and pull rod out it will have piston on the end with seals on it,and held on with a bolt.I bolt the eye of the rod to the bottom of loader bucket with a 1 inch bolt,put a block of soft wood under rod on piston end,You will need 3/4 drive socket,breakover bar and 6 foot pipe!!Get seals from whatever brand loader it is,HTH,BOB.
paul
11-13-2003 15:47:06
Some can be a job, but not too bad, you've done bigger jobs like the baler.
How is the shaft, might need to replace or resurface that.
What type of cylinder, some are welded, some are rods holding together, some are...
--->Paul
Kelly C
11-13-2003 17:40:11
 Re: Re: rebuilding a hydralic cylinder in reply to paul, 11-13-2003 15:47:06
I will take a photo and post it for you.
