ford 501 mower
Bill
11-13-2003 12:00:46
Is the ford 501 sickle bar mower a 3pt.hook-up or does it mount some other way?
norbert kanzler
11-15-2003 17:02:09
 Re: ford 501 mower in reply to Bill, 11-13-2003 12:00:46
Check with ford NH dealer I have a 501 and the operators manual there are a lot of ways to mount this mower to your 3 pt It takes differ brackets depending on the tractor model all off them are available from the dealer
Scott
11-14-2003 17:38:35
It is 3 point but also uses clamps on each lift arm, your lift arm can't be too thick or the lift arm will need ground down at the clamp points.
SmallOps
11-15-2003 06:04:34
 Re: Re: ford 501 mower in reply to Scott, 11-14-2003 17:38:35
Scott has a good point. If you are not attaching the 501 to a 3-Pt, Class I, Ford lift arm, then be sure you measure the width of the 3-pt arm on your tractor and compare it to an original Ford 3-Pt arm width
I found I could only grind down about a quarter of an inch on the clamp grooves and this was nowhere near what was required to make the 501 sickle mower fit my JD Tractor! I mounted a NH 451 Sickle Mower instead.
The local parts dealer informed me that these clamps, for the 501's 3-Pt arms, are the ONLY clamps made for the 501. That seemed strange... but parts guys know everything there is to know. Don't they?
Anybody need a 501... off a little Ford 861 Diesel???
jf
11-13-2003 13:09:15
3 point hook up with a swing arm to release as not to break the cutting bar. Good mower I have a 6 foot for sale 2 new cutting bars 300 dollars
