Haybalers
Ernie
11-09-2003 06:51:33
Could someone tell me what a six year old JD 348 square baler is worth? And what are some good brands of round and square balers that I can use with a 47 hp tractor. Thank you
Jim in michigan
11-13-2003 11:41:02
 Re: Haybalers in reply to Ernie, 11-09-2003 06:51:33
Square balers sell chep here, I have had several given to me including a really nice 24T ,,I use a NH 68 right now, but it is getting kind of shakey so I may use the 24T next season,,,,
kyhayman
11-10-2003 19:45:35
Neighbor bought a used 348 wire tie for $6500 few years ago. New 338 is about $12,000.
I've got a 336, pull it with everything from a 5600 Ford (at 60 hp and change) to a 2090 Case (at 105hp). Even used it with a 4000 Ford when dad bought it new back in the 70's.
14t
11-09-2003 20:48:17
JD 14T last Sat. 30.00
max
11-09-2003 17:28:03
Ernie
Bought lots of square hay bailers, we give 20 dollars a ton for them, cut em up for scrap. Leave the bidding to the experts. Go to a junk yard and get one for next to nuthin.
max
tlak
11-11-2003 03:29:53
 Re: Re: Haybalers in reply to max, 11-09-2003 17:28:03
So what state are all these cheap balers in?
Indydirtfarmer
11-10-2003 04:25:50
Max, before you 'scrap" any more old square balers, you might want to hook up with me. I buy and sell used equipment. I have a list of over 30 names, that are looking for cheap square balers. They are guys that have small acrage's and want to put up a few hundred bales a year. They don't want new or big stuff. I get a good price out of them usually. This baler mentioned in the original post, will be for my use, should I be able to buy it. I have a new Vermeer round baler, and a very nice JD 336 square baler, plus a NH 273, for a "back-up". I do some custom baling, and about 175 acres of hay for sale to "horse people" in my area. They want square bales. We also do about 4000 square bales of straw each summer. I sell it to landscape contractors primarily. There is a BIG market for square balers. So all the ones you "cut up" are just a waste of money, and your time. Call me, (E-mail me) when you get any you want to "dispose of". I'll haul them away, and save your acetylene and hacksaw blades. John
Loren
11-10-2003 17:08:59
 Re: Re: Re: Haybalers in reply to Indydirtfarmer, 11-10-2003 04:25:50
Hey Indy, what tractor are you running the 336 with? I know of a broken 336 here local that I may be able to get cheap and was wondering if the Ollie 77 standard would work well with it?
Indydirtfarmer
11-10-2003 17:31:00
 Re: Re: Re: Re: Haybalers in reply to Loren, 11-10-2003 17:08:59
Normally, it's behind either a 2440 Deere, (60HP), or a 4440 Deere (130HP) The 4440 is the smallest "cab tractor" I have. In hot weather it wins by default. The 2440 will handle it real well. On one occation this summer, I was forced to use it with an old Massey Ferguson 50. It is rated at 32HP. You definately knew it was back there, but it baled about 2000 bales of wheat straw. (Very slowly) I'm not sure what Deere's "recomended HP" is on that baler. My manual is at our other farm. I would think that your "Ollie" would handle it though. (Even if it didn't, that is a good selling baler.) Hope this helps, John
Tim(nj)
11-10-2003 17:27:00
I ran a 336 with ejector with an MF65 gas with no problem, so your 77 should be able to do it. Does your Ollie have live PTO?
Loren
11-11-2003 16:02:27
 Re: Re: Re: Re: Re: Haybalers in reply to Tim(nj), 11-10-2003 17:27:00
Yep, hand lever by the seat. It must weigh almost 7000 lbs. with the loader but it's only about 35-40 horse I think. You still think it'd do ok for the flat ground I bale on without any additional hooked on? Loren
Tim(nj)
11-11-2003 18:11:29
 Re: Re: Re: Re: Re: Re: Haybalers in reply to Loren, 11-11-2003 16:02:27
You'll be fine. From what I recall, JD recommended 35HP min. A guy a few miles away ran one with a Farmall M (that had an M&W hand clutch for "live" PTO), until he quit last year. He pulled a wagon behind his. My MF65 only weighs about 5000 lbs. Never lacked on HP (45), but sometimes the wagon and baler together could get to pushing it down a hill.
Loren
11-12-2003 17:36:11
 Re: Re: Re: Re: Re: Re: Re: Haybalers in reply to Tim(nj), 11-11-2003 18:11:29
You don't know how much I appreciate the info on the experience you and your heighbor have had. Thanks you, Loren.
NHBalerman
11-09-2003 18:40:22
Max Where are you located? Sure would like to save you the trouble of cutting them up and saving the New Holland balers.
jf
11-09-2003 12:41:44
On the round baler. I believ in the vermeer line. I fyou want to spend the money get a new Rebel 5400 11000-14000 depending on dealer. If you want a used one get a 504 model. The other good option ia NH
Indydirtfarmer
11-09-2003 07:15:14
Sounds like you're heading to the same auction I am, next saturday. If you want to know what that 6 year old 348 baler is worth, just watch to see when I stop bidding. There's your answer.
Taking the 5th.
11-09-2003 14:43:46
 Re: Re: Haybalers in reply to Indydirtfarmer, 11-09-2003 07:15:14
Which just go to show you that the true value of anything is whatever you can sucker some hoosier into bidding on it.
Indydirtfarmer
11-09-2003 14:48:06
 Re: Re: Re: Haybalers in reply to Taking the 5th., 11-09-2003 14:43:46
Then we just list them on E-Bay, and the rest of you come a runnin', with dollars in hand, just to own something from God's country.
Van
11-11-2003 09:08:58
 Re: Re: Re: Re: Haybalers in reply to Indydirtfarmer, 11-09-2003 14:48:06
God's Country? Your not from the Ozark mountains are you Indy? When I die they can take me to NY city for all I care. LOL Van
JD-Tractor
11-09-2003 15:48:08
God's country !!!! I didn't know you was from Western NY Indydirtfarmer!!!!!
Indydirtfarmer
11-09-2003 16:40:17
 Re: Re: Re: Re: Re: Haybalers in reply to JD-Tractor, 11-09-2003 15:48:08
I have a sign in my "office" that says, "If you live by the bibles teachings, treat everyone like they're your best friend, respect everyone, and work hard every day, when you die, you'll go to INDIANA" Can't argue with that. John
tim[in]
11-09-2003 17:27:44
 Re: Re: Re: Re: Re: Re: Haybalers in reply to Indydirtfarmer, 11-09-2003 16:40:17
that was before we fired bobby knight!! lol
Indydirtfarmer
11-09-2003 17:34:13
 Re: Re: Re: Re: Re: Re: Re: Haybalers in reply to tim[in], 11-09-2003 17:27:44
At least he's doing some good. Down there teaching them "Texicans" how to play b-ball
Ernie
11-09-2003 15:09:12
Yes Indydirtfarmer we might be going to the same auction next Saturday. See you there.
Indydirtfarmer
11-09-2003 15:12:47
 Re: Re: Re: Re: Re: Haybalers in reply to Ernie, 11-09-2003 15:09:12
OK! I'll be the one in the John Deere hat, and the bib over-alls. (And bidding on the baler)
Kelly C
11-12-2003 22:10:20
 Re: Re: Re: Re: Re: Re: Haybalers in reply to Indydirtfarmer, 11-09-2003 15:12:47
Not likely to see any one else dressed like that eh?
Hay Dr
11-09-2003 11:13:02
Great Answer
